Old 11-25-2011, 09:28 AM   #1
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
RB RB25 believed to be leaning out under boost, opinions on my diagnosis
Swapped in an S2 RB25DET about a month and a half ago. Have been completely unhappy with the performance.
Mods: ISIS intake w/ Q45 TB & TPS, top mount tubular mani, Master Power 57 Trim, FMIC, Greddy RS, 38 mm external WG running .5 bar spring no boost controller, adjustable fpr set around ~48psi
Symptoms: Slight missfire at idle, strong missfire at 10-15% throttle (jolts me forward in my seat), lack of power, boosting at 5500 (I attribute that to the large turbo and being untuned), spark plugs showing lean (no wideband), slight break up under boost, backfire when decelerating in gear which becomes very strong (think fireballs that light up the entire street) after coming off boost.
My diagnosis: I think that due to high under hood temps the rb generates the maf is getting warm and not reading airflow correctly. My theory being the actual sensor wire is warming due to atmospheric temperature and not getting cold enough to read the airflow coming through it resulting in the lean condition. Unfortunately I do not have a wideband at this time to measure the AFR, but like I stated earlier the old plugs I pulled showed signs of running lean and did not even smell like fuel. I've installed an adjustable FPR to boost fuel pressure to remedy the issue but it had no noticable affect on the condition. I also swapped out the Autolite spark plugs that came with the motor for NGK BCPR6ES-11 regapped to .8mm (.031).
Does my diagnosis have any ground or does anyone have any other suggestions?
KendallH is offline   Reply With Quote
Old 11-25-2011, 04:17 PM   #2
Kingtal0n
Kingtal0n's Avatar
1. You need a wideband, .
2. What have you done for a tune? It needs tuning, that is my diagnosis from over the internet without seeing it.
Old 11-25-2011, 05:15 PM   #3
KendallH
Yes, I know I need a wideband and a tune badly. Its currently running the bone stock ecu. I imagined that even with the different turbo setup, running stock boost would be OK, being I've seen people crank RB25s up to 10-12psi on a stock setup.
Old 11-25-2011, 06:44 PM   #4
Zacho
Zacho is an unknown quantity at this point
Stop driving your car. You could have done irreversible damage by now. For the same boost pressure a larger turbo flows more air. I hope you have larger injectors.
Zacho is offline   Reply With Quote
Old 11-29-2011, 12:52 PM   #5
Brok3n_RB25
Brok3n_RB25 is an unknown quantity at this point
A stock boost number (7psi for RB25s) doesn't mean that it's flowing the same amount of air. Think of it like a hose. You put a regular garden hose at 7psi and it has a set flow. You put the same pressure through a fire hose and it's going to flow a hell of a lot more. You NEEEEEEEEED a tune. You might have already done irreversible damage just as the previous post states.
Brok3n_RB25 is offline   Reply With Quote
Old 11-29-2011, 01:05 PM   #6
DJDANGER24
DJDANGER24's Avatar
/\What he said/\
Tune the bitch and quit half-assing it
DJDANGER24 is offline   Reply With Quote
Old 11-29-2011, 09:41 PM   #7
cotbu
cotbu's Avatar
Not saying you don't have a mafs problem?!? just your "theory" is wrong! If you have ever taken the temperature of the hot wire element, you'd know what I mean.
Old 11-29-2011, 11:04 PM   #8
Brok3n_RB25
Oh, and unless you're overheating... under hood temps won't effect you that much.
Granted heat soak is a bitch, but I daily drove my RB this past summer here in Phoenix.
Old 11-30-2011, 06:09 PM   #9
r33nota240
r33nota240's Avatar
r33nota240 is an unknown quantity at this point
sounds like ur timing is off.
r33nota240 is offline   Reply With Quote
Old 11-30-2011, 06:12 PM   #10
r33nota240
r33nota240's Avatar
or a mix between timing and tps sensor.
Old 12-01-2011, 12:58 PM   #11
shoguner
shoguner is an unknown quantity at this point
Sounds like you know what you need. Now go do it!
shoguner is offline   Reply With Quote
Old 12-11-2011, 05:34 PM   #12
S13-RB25
S13-RB25's Avatar
S13-RB25 is an unknown quantity at this point
Hello all. I'm new to zilvia. I recently swamped and rb25 into a 92 s13 coupe. Right now i have a greddy downpipe, greddy intercooler, greddy bov, greddy air filter, greddy intake manifold, nismo fuel pressure regulator, his wastgate actuator set to 13psi of boost walbro 255 lph fuel pump. After changing plugs i started getting a hesitation its progressively gotten worse. Ive swapped plugs back out, tried another fuel pump, changed fuel filter, mafs, crank angle sensor, wired a separate relay for the fuel pump, different coils, checked and repaired boost leaks, regrounded the pcm and coils, tested the knock sensors checked the injectors to be sure they weren't clogged, tried more and less fuel pressure, quadruple checked the timing, changed the tps, tested the coolant temp sensor, lowered the boost... pretty much everything besides the ecu. Starts hesitating under boost but normal driving is fine. Sounds like a bee r but it keeps revving. Im worried I'm going to destroy the engine with how violent it hesitates and backfires. I'm pretty much out of ideas and am looking for more. Ive already spent over $500 trying to fix it. If anyone can give me some insight as to what's going on I'd be very grateful. Sometimes the problem isn't there but its very rare. I dont have a wideband but o2 sensor voltage at wot is .920mv
S13-RB25 is offline   Reply With Quote
Old 12-12-2011, 02:50 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
does it hesitate all the time (warm or cold engine)? When you said you swapped out the plugs, what plugs did you run and what gap? Also, did you double check the timing on it? I've seen the CAS up front come loose and advance the timing from the baseline and run like shit.
CLICK HERE!!!
Old 12-12-2011, 03:22 PM   #14
S13-RB25
S13-RB25's Avatar
Ngk bkr7eix-11 tried em at 1.1 gap and .8 gap. It had autolites in it. That's what i put back in. Its holding 60psi of fuel pressure. Every now and then it'll run right. But rarely. I have alternator volts at the injectors and ignition coils. I think either sparks breaking down or its loading up with too much fuel but i see no smoke. It seems i see a lot of people with this type of problem but can never find put what they've found wrong. Maybe its the ignition driver in the ecu. Just hate to spend more money on something that might not fix it. At 13 psi and stock Turbo maf is reading 4.80 volts haven't a clue if that's right. I checked the timing several times. Dead on. And it does it no matter the temp hot or cold.
Old 12-12-2011, 06:38 PM   #15
Sileighty_85
Sileighty_85's Avatar
Autolites are garbage
Get some NGK's and drop the gap down to .028
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-12-2011, 06:56 PM   #16
S13-RB25
S13-RB25's Avatar
Yea i think so too that's why i put the ngk plugs in it. That's when all my problems started lol. What ngk plug do you recommended? I tried iridiums.
Old 12-12-2011, 07:01 PM   #17
Sileighty_85
iridium's are fine, but having too big of a gap will blow out the spark.
後輪駆動車1番
1986 SR86 - 200ish
Old 12-12-2011, 07:19 PM   #18
S13-RB25
S13-RB25's Avatar
Yea ive gapped them down too. Forgot to meantion that.
Old 12-12-2011, 07:32 PM   #19
EjMalernee
EjMalernee's Avatar
EjMalernee is an unknown quantity at this point
Might be a coil going out and acting funny. What are you tuned on or is it stock ecu.
EjMalernee is offline   Reply With Quote
Old 12-13-2011, 07:11 AM   #20
S13-RB25
S13-RB25's Avatar
I replaced the coils. Yes with used one but i really think it would have changed something. Knock sensors have 2.5v with the engine running and 560k ohm resistance with the engine off. I'm beginning to think maybe they are showing their age and are over sensitive, picking up knock when its not there and its enriching the f/a ratio and over retarding the timing. I am running the stock ecu that came with the swap but it didnt do this right after i turned the boost up. I was running 13 lbs for 3 months without a single problem. Only thing i did was put iridium plugs in it. But again i think that was a coincidence. I'm thinking of wiring in resistors to eliminate the knock sensors and try it. If it clears up ill replace them. Dont quite have any other ideas.
Old 12-13-2011, 08:09 AM   #21
epson1
Trader Rating: (-1)
epson1 is an unknown quantity at this point
Feedback Score: -1 reviews
you know whats cheaper than replacing all that stuff?? a wideband....
epson1 is offline   Reply With Quote
Old 05-20-2014, 12:40 PM   #22
Rb25d
Rb25d is an unknown quantity at this point
60psi is to much. Should run around 38psi of gas
Rb25d is offline   Reply With Quote
Old 05-25-2014, 05:08 AM   #23
Croustibat
Upping a 3 year old thread with a useless comment. Isn't that punishable by death ?
Old 05-25-2014, 01:14 PM   #24
Kingtal0n
Kingtal0n's Avatar
To escape is only the goal when the ship is sinking. To gain entry and live while it still floats is the way of life.
It beats living in a suspended shell beneath the crust of Earth.
tinyurl.com/4l80er
