Old 05-30-2014, 01:03 AM   #1
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Parting S13 SR RHD Convertible, S14, Miata TONS OF EVERYTHING!!!
Parting out a S13 RHD SR Convertible AND a complete Miata. Every nut and bolt is for sale so text or message what you need.
Located in Petaluma CA.
Updated the list 6-9-14
(415) 724-0675
MIATA PARTS !!!!!!!!!!!!WING IS SOLD!!!!!!!!!!!!
OEM Hardtop - $900
Autokonexion Hood - $400
Wide Body Front Fenders - $350
Autokonexion Rear Over Fenders - $350
JIC FLT Coilovers - $800
WOT Drift Knuckles - $300
Stock Miata Knuckles - $40
Diff and Axles (1.8 welded with solid spacers) - $350
CNC Hydro Ebrake and Lines for Miata - $250
Adjustable Megan Racing RUCA's - $100
Manual Steering Rack - $200
Stock White Miata Hood - $40
Miata Bumper Lights - $40
Yellow square Hella headlight upgrade, everything to bolt on - $300
ENGINE PARTS --Parting a complete SR, message with what you need--
SR Red Top Thermostat Housing - $10
SR20 Flywheel Bolts - $20
S13 KA24DE Fan - $20
S13 KA24DE Air Box - $20
SR20 Redtop IACV - $65
ACT 6 puck sprung hub clutch/heavy pressure plate (new clutch disk, pressure plate in good condition, 1 season) - $300
SR20 Coil Packs (4) - $100
SR20 Coil Pack Harness - $75
SR20 Redtop Valve Cover, powder coated white - $75
SR20 Redtop throttle body with TPS - $50
Z32 Maf Pigtail - $15
SR20 maf adapter with filter - $40
SR20 Redtop Alternator Bracket - $60
Greddy Blow Off Valve - $150
SR Oil Filter Relocation and Oil Pressure Sensor - $150
Mishimoto Universal Intercooler Core - $150
SR CAS - $120
Complete Side Mount Intercooler - $180
Stock SR injectors and Rail - $175
SR Transmission - $280
SR Head and Block (blown HG) - $500
SR Alternator - $60
SR PS Pump - $60
SR Knock Sensor - $40
SR throttle body with TPS - $50
DRIVETRAIN
S13 Rear Subframe (local only) - $80
S13 4 Lug Hubs (rear only) - $35 per pair
S13 Plate Welded Diff - $120
5 Lug Rear Hubs - $125
5 speed non ABS drive shaft - $90
SUSPENSION
S13 Tein HE Drift Coilovers - $700
S13 Godspeed Tension Rods - $50
S13 Megan Racing Rucas - $90
Pairs of 5x114.3 10mm slip on spacers - $25
S13 Driver Side tension rod bracket - $35
S14 Stock knuckles - $50
Stock S13 springs and shocks - $60 for all 4
I have most stock suspension so let me know what you need
BRAKES
Stock Rear Bracke Calipers - $40
2 Brembo Blank Z32 rear rotors (good condition) - $40
Carbotech race Z32 rear brake pads - $30 (retail for $175)
WHEELS
(2) Volk 17x7 + 40 4x114 (no tires) - $250
(4) Enkie Big End Barrels 15X8 -15r / +5f 10 spoke (4x100) - $1600
(4) Axis OG Racer X - 15x8 -27 4x100 - $1600
INTERIOR
S13 RHD Conversion - EVERYTHING you need!! - $1000
-Dash
-Cluster
-Pedals
-Steering rack
-Brake Master
-Brake booster
-Dash Bar
S13 Clean Dash - $150
S13 Cluster Surround - $35
S13 Steering Wheel Adapter (nardi pattern) - $20
S13 Rear View Mirror - $15
S13 Seats (pair) - No tears - $50 (will not split)
S13 Rubber shift boot - $40
S13 Window Switches - $80 (will not split)
S14 Glove Box, grey or black - $40
S14 Confetti rear seats - $50
S14 Cluster Surround - $35
S14 Center Console - $50
S14 Interior Mirror - $20
S14 Steering Column Switches (blinkers, windshield wipers etc.) - $35
S14 Steering Column Trim - $20
S14 Carpet - $60
Universal Switch Panel - $30
EXTERIOR
S13 Hood - $60
S13 Hatch Rear Bumper (primer) $35
S13 Fastback Center Tail Light - $35
S13 Fastback Passenger Side Tail Light - $30
S13 Doors (local only) - $40 each
S13 Manual Mirrors (clean, won't split) - $50
S13 Chuki Bumper - $30
S14 Zenki tail light center panel - $35
S14 Zenki Driver Side Tail Light - $30
CWest rear wing (pictured on the black coupe NOT THE MIATA WING) - $150
R33 Tail Light - $100
MISC
S13 Hood latch with cable - $25
S13 Upper Radiator mounting brackets - $15
S13 Gas Tank Door - $15
S13 Steering column - $40
S14 Gas Tank (local only) - $100
S14 Steering Column - $40
(415) 724-0675
Text with what you need. I have 2 complete cars and every spare part ever.
DJPimpFlex is offline   Reply With Quote
Old 05-30-2014, 02:02 AM   #2
xARxxImPoRtx
xARxxImPoRtx is an unknown quantity at this point
Do you have an s14 shift boot and trim available? Thanks
xARxxImPoRtx is offline   Reply With Quote
Old 05-30-2014, 09:55 AM   #3
DJPimpFlex
DJPimpFlex's Avatar
I don't unfortunately.
Old 05-30-2014, 08:35 PM   #4
gzer750
gzer750's Avatar
gzer750 is an unknown quantity at this point
Selling vert top?
gzer750 is offline   Reply With Quote
Old 05-31-2014, 01:35 PM   #5
DJPimpFlex
DJPimpFlex's Avatar
Originally Posted by gzer750 View Post
Selling vert top?
Unfortunately the car didn't come with a top.
Old 05-31-2014, 01:39 PM   #6
Philthese93
Philthese93's Avatar
Philthese93 is an unknown quantity at this point
The way the list is put together is tits. Glws!
Philthese93 is offline   Reply With Quote
Old 05-31-2014, 05:37 PM   #7
DJPimpFlex
DJPimpFlex's Avatar
Thank you! List updated, sold some things.
Old 05-31-2014, 07:16 PM   #8
Konster
Konster's Avatar
Konster is an unknown quantity at this point
Got interior rear panels?
Hyer.
Konster is offline   Reply With Quote
Old 05-31-2014, 07:24 PM   #9
DJPimpFlex
DJPimpFlex's Avatar
Negative sorry
Old 05-31-2014, 11:13 PM   #10
DJPimpFlex
DJPimpFlex's Avatar
Added a bunch of stuff today. Come get some!
Old 06-01-2014, 05:27 AM   #11
sr vegas 240
sr vegas 240 is an unknown quantity at this point
tein coils and gsp tension arms to 89148 pm please
sr vegas 240 is offline   Reply With Quote
Old 06-01-2014, 08:24 AM   #12
chankisonfire
chankisonfire's Avatar
chankisonfire is an unknown quantity at this point
ship the dash?
chankisonfire is offline   Reply With Quote
Old 06-01-2014, 10:51 AM   #13
DJPimpFlex
DJPimpFlex's Avatar
Originally Posted by chankisonfire View Post
ship the dash?
No thanks...
Old 06-01-2014, 02:45 PM   #14
chankisonfire
figured haha
Old 06-01-2014, 03:44 PM   #15
bskiles92
bskiles92's Avatar
bskiles92 is an unknown quantity at this point
is the sr O2 sensor the skinny or fat?
bskiles92 is offline   Reply With Quote
Old 06-01-2014, 10:00 PM   #16
DJPimpFlex
DJPimpFlex's Avatar
I think I have both. Same price.
Old 06-02-2014, 03:44 AM   #17
zenki_ftw
zenki_ftw is an unknown quantity at this point
how much for greddy style intake manifold?
zenki_ftw is offline   Reply With Quote
Old 06-02-2014, 11:27 AM   #18
DJPimpFlex
DJPimpFlex's Avatar
That has been sold sorry.
Old 06-02-2014, 12:24 PM   #19
yoko86
yoko86 is on a distinguished road
s13
i will buy dash and cluster 300 for both?
I ate the "Devilz fruit" .
yoko86 is offline   Reply With Quote
Old 06-02-2014, 12:25 PM   #20
DJPimpFlex
DJPimpFlex's Avatar
I don't really want to part out the RHD stuff. Trying to sell it complete.
Old 06-02-2014, 01:08 PM   #21
s13mikesr20
s13mikesr20 is an unknown quantity at this point
Sr20 maf sensor sir
s13mikesr20 is offline   Reply With Quote
Old 06-02-2014, 05:46 PM   #22
DJPimpFlex
DJPimpFlex's Avatar
Originally Posted by s13mikesr20 View Post
Sr20 maf sensor sir
Sold that already, sorry.
Old 06-03-2014, 12:14 PM   #23
DJPimpFlex
DJPimpFlex's Avatar
Bump! List updated
