Old 06-19-2014, 11:53 PM   #1
Drifters
Drifters is an unknown quantity at this point
Clutch slipping?
Hi, I have an sr20 hatch that just recently started having an issue, when i'm driving if I give the car more then 50% throttle the RPM's will go up but my car wont go, then after like 2 seconds it catches and the car speeds up, in every gear. Is the clutch slipping? something with the transmission? Car is stock, thanks for inputs
Drifters is offline   Reply With Quote
Old 06-20-2014, 07:48 AM   #2
So Make Like
So Make Like's Avatar
So Make Like is an unknown quantity at this point
your clutch is slipping. stop driving the car, or learn to cope with it until you can change the clutch; ie. when you see a hill, try to gain some momentum before you hit the hill and taper off the throttle as you ascend to attempt to save every last bit that you can. learn at what amount of throttle will slip it and try to work with it. drive only if you have to. if it blows up on you, you're stuck.
So Make Like is offline   Reply With Quote
Old 06-21-2014, 10:52 PM   #3
Drifters
Thanks, I apprecaite the feedback
