Old 07-21-2014, 04:41 PM   #1
Alan240sx
Alan240sx's Avatar
Alan240sx is an unknown quantity at this point
s13 5 Speed swap List and Questions
I don't want to get flamed lol.
(not Sure if it's in the right place don't really post on here)
I have owned a couple 240's this is one of the first one that I'm going to build. Starting off with a Virgin automatic gonna swap it to Manual.
I know this has been covered a lot of times (I've read them all but still no help) I'm sourcing all the parts. Just want someone to tell me if I have almost everything? I appreciate any input Positive/Negative.
*LIST OF ITEMS*
Isis Auto to manual clutch conversion line
Competition Clutch Kit - Nissan 240SX "White Bunny" 6 Puck
Nissan OEM clutch Pedal
Stock Brake pedal (Gonna cut it up)
Nissan OEM clutch master assembly
Nissan OEM slave cylinder
Nismo Transmission mount
5 Speed DriveShaft non abs
5 Speed crossmember
5 Speed Trans
(gonna run the auto ECU)
Now I recently found someone talking about the Clutch Hardlines and clutch cable? What's the difference? Since I got the isis auto to conversion line do I need them? I was looking at the Chasebays clutch line also
just trying to make sure if I need or do not need something's.
Thank you!
Alan240sx is offline   Reply With Quote
Old 07-21-2014, 04:47 PM   #2
seeks14
seeks14's Avatar
seeks14 is an unknown quantity at this point
There's something called the search tab... It may sound unreal but it's there's bro..
JDM-FIEND.COM
ASE cert.
seeks14 is offline   Reply With Quote
Old 07-21-2014, 05:10 PM   #3
Alan240sx
Alan240sx's Avatar
i guess lol.
Old 07-21-2014, 05:12 PM   #4
Silviastunter
Silviastunter is an unknown quantity at this point
If you have the isis line that will work just fine. Some people just like using hard lines for oem look. Make sure you replace that TOB too
Silviastunter is offline   Reply With Quote
Old 07-21-2014, 05:15 PM   #5
Silviastunter
Oh and order all the hardware flywheel bolts I would use oem or ARP. Pressure plate bolts ect.
Old 07-21-2014, 05:25 PM   #6
Alan240sx
Alan240sx's Avatar
Finally thanks silviastunter! I was gonna replace the Tob anyways. another question where can I order all the bolts? Enjuku?
Old 07-21-2014, 05:29 PM   #7
Silviastunter
I usually order from Frsport.com
Old 07-21-2014, 05:36 PM   #8
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Your missing the flywheel and shifter on that list.the auto trans uses a flexplate that won't work with a 5 speed trans..
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 07-21-2014, 05:41 PM   #9
NISR20MO
NISR20MO's Avatar
Trader Rating: (29)
NISR20MO is an unknown quantity at this point
Feedback Score: 29 reviews
Comp clutch white bunny kit includes a flywheel.
NISR20MO is offline   Reply With Quote
Old 07-21-2014, 05:57 PM   #10
djnicky240
djnicky240 is an unknown quantity at this point
Send a message via Yahoo to djnicky240
+1 Frsport! Also you may want a Rubber Shift Boot and a manual interior trim.
djnicky240 is offline   Reply With Quote
Old 07-21-2014, 06:55 PM   #11
shinhed
shinhed's Avatar
shinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of light
Make sure you get the 5-speed transmission dust cover. Isn't that necessary, but does it's job, and my 5-speed swap project is on jack stands waiting for it's arrival.
shinhed is offline   Reply With Quote
Old 07-21-2014, 08:27 PM   #12
Alan240sx
Alan240sx's Avatar
Thanks guys for clearing it all up ordering my last few things!
Old 07-22-2014, 07:11 AM   #13
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
Does the Isis conversion line go all the way to the slave cylinder, or will he still need the short hose from slave to where the stock hard line ends?
LoSt180 is offline   Reply With Quote
Old 07-22-2014, 08:18 AM   #14
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
And dont forget about the wiring! Lol
Remember to by pass the old auto starter signal wire by taping them together, or runn it to ur clutch pedal for safety??
Primo's Silvia is offline   Reply With Quote
Old 07-22-2014, 09:52 AM   #15
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Run it to a relay, don't run the start signal wires directly to the clutch pedal.
The old wires next to the fuse box come in very handy to get wires into the cabin cleanly.
Old 07-22-2014, 05:58 PM   #16
Alan240sx
Alan240sx's Avatar
I'm already thinking about the wiring! Thank you all for the great feedback it helped a lot. If I have anymore questions I'll post them here
Old 08-12-2014, 07:10 PM   #17
djnicky240
If its an S13 no need to wire up the clutch pedal. Get used to pushing in the clutch pedal when you start the car or make sure she is in neutral.
Old 08-14-2014, 10:46 AM   #18
Goofs
Goofs's Avatar
Goofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of lightGoofs is a glorious beacon of light
Definitely some useful info in here. I heard the difficulty on this isn't too bad. Also, whast the price range for the whole swap
Originally Posted by silviasandbeer View Post
bump for a JDM Bangbus
Goofs is offline   Reply With Quote
