Old 07-22-2014, 03:37 PM   #1
bonomo
bonomo can only hope to improve
Nistune problem on my ka-t
Ok little on my set up s13 ka-t with
6262
id1000cc injectors
z32 maf
heres what happened last time i drove the car it ran good untill right at the last couple min then i jumped like a big miss . then i went to start it up the next day and i seen a fuel leak so i fixed that and i wanted to replace my fuel pump from a 255 to a 400 . after all that it starts up revs ok then after it warms up its revving high and its like hitting fuel cut at like 4000rpms. its weird i replaced my tps did nothing and it reads the right volts. thought it could be my maf but the volts are reading right on the nistune .
did a pressure check all is good. whats yalls thought on this? could i of messed up a setting in the tune? thanks ahead!
bonomo is offline   Reply With Quote
Old 07-23-2014, 09:51 AM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
did you try to re-load your tune?
supersayianjim is offline   Reply With Quote
Old 07-23-2014, 12:37 PM   #3
Croustibat
Jump with a big miss, fuel leak ... i'd check pistons and spark plugs before worrying about the fuel pump ...
There is a very nice feature on nistune that allows you to compare 2 tunes. Load your stored tune in the second slot, read the current tune in the first, hit the compare button/checkbox/dropdown menu where you can (fuel and timing maps allow it), and you will see the differences.
Old 07-23-2014, 07:42 PM   #4
bonomo
well here is the thing i accidentally uploaded and burned the the current tune on there right before this happened . and i dont remember what one i had on there cause it was a while ago!
Old 07-24-2014, 01:42 PM   #5
supersayianjim
well kiddo you need to start from scratch then. consult the nistune support forums.
Old 07-24-2014, 06:03 PM   #6
G-E@Z31P
G-E@Z31P is an unknown quantity at this point
Well as long as you didn't burn a new base image to the board, it should operate the ecu correctly, which means you just have to re-tune everything...
If you're really lost, start with the stock maps, resize injectors, change maf curve, then start tuning again (or pay someone)
G-E@Z31P is offline   Reply With Quote
Old 07-24-2014, 07:59 PM   #7
bonomo
ok its weird i replaced the spark plugs the cap and rotor still the same . but if the cars cool it will not do it. The throttle response is bad though . like it i punch it it hesitates then revs. the a/f is great though at idle and when revving ! it seems like it would be the maf sensor but the volts are consistent with what the oem specs.
Old 07-27-2014, 04:22 PM   #8
bonomo
anyone else? im trying to get on the nistune forum but i cant post yet!
Old 09-01-2014, 08:15 PM   #9
bonomo
Anyone ? i bought a new tps car ran a little better but it still does the miss at 4k. and its running good a/f but the plugs are showing super rich!
