Old 10-07-2004, 01:42 AM   #1
dori2 s13coupe
dori2 s13coupe is an unknown quantity at this point
Send a message via AIM to dori2 s13coupe
manual ecu in a swap
~s13~ SO.. im doing a auto to manual swap.. i kno i have to relay the top connectors for the auto ecu and all that.. BUT what if i use a manual ecu... will i have to relay still and/or will i have to do more wiring? and will the auto harness plug into the manual ecu? reason im using a manual ecu is because it is reprogrammed with a higher fuel curve
Signature Not Available
dori2 s13coupe is offline   Reply With Quote
Old 10-07-2004, 12:53 PM   #2
dori2 s13coupe
no one knos?
Old 10-07-2004, 03:51 PM   #3
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
what u mean, Im using the 62 redtop ecu, I have a new harness also but it should be the same, all ecus should line up, then no matter what u do u still need to jump those 2 wires, its so simple (yet ill agree before I did it I didnt know what to do and looked to be too hard) all the wiring I think I did was jumper that connector, and it turned over, I didnt start it as im not even close to getting it running yet.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
