Old 07-30-2014, 05:30 PM   #1
ZAcardo
ZAcardo is an unknown quantity at this point
Sr20det help !
So my sr died about a week ago . It has been leaking oil for a while before this happened .
Alright so i drove to the corner of my street and it turned off on me, after about 5 min of trying to keep it running without it dying , i decided to push it back to my house . I pushed it about 10 feet back and saw it leaked out soooooooooo much oil ! ImageUploadedByTapatalk1406762781.264445.jpg
After that i took another pic of where the oil seems to be coming from.
So its been sitting ever since, im not that good with sr's, (or engines in-general) but ive been told that it was just the timing chain gasket? And could that cause it to start then die? Just wondering if its a pretty easy fix or am i fucked? Thanks
ZAcardo is offline   Reply With Quote
Old 07-30-2014, 09:49 PM   #2
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
Looks like the front crank seal. Pretty easy fix if you have an impact gun. I would drop the oil pan and see if you see any metal shavings. If no, you "should" be good.
Kaifd3s is offline   Reply With Quote
Old 07-30-2014, 10:41 PM   #3
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Hard to diagnose the leak through the internet but I'd start by 1. Fixing your coolant leak in that area which I take is the water pump and 2. The front main seal. But for a leak that big you probably hit something and dented your oil pan if your lowered..and if it is after all dented, check your oil pickup! If that's damaged at all replace that unless you want it to blow up.!
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 07-30-2014, 10:43 PM   #4
angel mkiv
angel mkiv's Avatar
Hopefully you didn't drive if to long without oil and you can still save your engine..and as for your no start issue you need to tell us a little more then it died..give us more details..
Old 07-30-2014, 10:45 PM   #5
ZAcardo
Hmmmm well it started up then would do a couple of wob wob wobs and die , i really dont know how to explain it lol
