![]() Join Date: Jun 2013
Can I add my own fuse to the fuse box?
I'm currently rewiring my radiator fans, and I need to install a 30 amp fuse.
I want to install it in the factory fuse box to keep a clean look, but I don't know if I can do that. There is a slot that's unused, but it only has an input terminal, and the output terminal (the metal terminal that the fuse slips into) is empty. Can I just insert my own terminal into there and run it to a wire? If so, how? Has anybody done this before? Any input would be appreciated, thanks. |
#2 | |
GM2 (SW/AW)
On the main fuse box there are typically a few fuse slots that aren't used.
On my first 240 I threw a fuse in there and just ran the female spade connectors into it like it was meant to be.
KA-T for life! Current for sale advertisement ![]() |
![]() Join Date: May 2011
I had an extra fuse box at the time but all the little fuse "clusters" will come out of the fuse box if you push the plastic clip, then you remove a thin plastic strip from the side and it allows you to de-pin or re-pin the fuses. I used an empty fuse slot as well as an empty relay slot and ran all the wiring for my fans, looks much better than a relay hanging in the engine bay. Good luck!
![]() Join Date: Jun 2003
Trader Rating: (130)
we did this on my brothers truck (d22 frontier with s13 blacktop sr20)
it had a few empty spots and we needed to add another fuse. worked out fine. |
