Old 08-11-2014, 02:47 PM   #1
EthanR
EthanR is an unknown quantity at this point
Send a message via AIM to EthanR
Mazworx CTSV Caliper bracket w/ V2 caliper
Hey everyone. Something I've really wanted to do lately was bigger brakes. CTSV brakes seem to be the best bang for your buck option at the moment.
Mazworkx makes the s13/14 > CTS-V conversion brackets for the CTS-V V1 Caliper. On their site they state that the kit uses Evo VIII rotors to complete the kit.
http://www.mazworx.com/store/p/87-Ca...s-S13-S14.aspx
Personally however, I'd rather use the larger, V2 calipers. You can see the difference here:
Of course the V1 is actually mounted whereas the V2 is just sitting there. The V2 is a 6-piston setup, and in my opinion, looks MUCH better.
I did a little research and found out that for CTS-V guys this was a direct swap apart from the rotor. So mounting holes must be the same. I emailed Mazworx and explained what I was trying to do. They told me that they would mount just fine, however they do not know what rotors to use.
Has anyone ever done this? And if so, what rotor / conversion lines should be used? I'd rather know it all before I pull the trigger on everything.
Thanks.
EthanR is offline   Reply With Quote
Old 08-11-2014, 03:39 PM   #2
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Evo x rotor are bigger then evo 8/9
I would try it out !
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 08-11-2014, 03:43 PM   #3
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
EVO X rotor size > 6 piston caliper. Id just do the evo 8&9 calipers with the 350mm rotor.
e30gangsta is offline   Reply With Quote
