Old 08-07-2014, 07:56 PM   #1
solo_ryder
solo_ryder's Avatar
Trader Rating: (18)
solo_ryder is making a name for him/her selfsolo_ryder is making a name for him/her self
Feedback Score: 18 reviews
Deceleration vibration issues..
I have had this issue for some time.. When I am cruising in 3rd or 5th at about 2.5-3.5k rpms (usually highway around 70-80mph in 5th) and I let off the gas completely to decel the rear end vibrates. Its really annoying.. 1st, 2nd and 4th have no issue at any speed or RPM.. I am not sure what it is and want to know if others have had this issue. Here are some factors that I think may cause the issue:
I have stock mounts that have 3m window weld on the outside ribs
Stock trans mount that was just changed, helped a very small amount, OEM.
Recent clutch (white bunny flyhweel and clutch assembly from comp clutch, organic disk)
stock VSLD which Im pretty sure is not locking up anymore
I did notice when I pull the ebrake up almost 90% of the vibration goes away in the back end goes away?? If im accelerating everything is OK.
Any ideas? I tried swapping the driveshaft around 180deg did nothing. Carrier bearing seems to be ok, its not broken or anything..
solo_ryder is offline   Reply With Quote
Old 08-21-2014, 04:55 AM   #2
kota2240
kota2240 is making a name for him/her selfkota2240 is making a name for him/her self
If you have a spare diff swap it out real quick...My problem was the pinion bearing in the diff. Easier to just swap the pumpkins. Mine would do it at various gears and rpms too.
kota2240 is offline   Reply With Quote
Old 08-21-2014, 06:45 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You double checked all the driveshaft bolts are tight?
CLICK HERE!!!
Old 10-19-2014, 09:20 AM   #4
solo_ryder
solo_ryder's Avatar
Trader Rating: (18)
Yup all bolts are tight and dont seem to have excess play in the carrier bearing.. diff or mounts?
