Old 10-16-2004, 09:49 AM   #1
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
SR shes alive! sort of...
I recently swapped an s13 blacktop into my 97. After fixing my faulty MAF wiring(doh) the car is running ok. However the idle fluxuates from 1100-900RPM while sitting, if i rev the motor high and let off, the idle will drop to 300-400 and come back up. When im driving the car it stalls CONSTANTLY. If I let the idle fall to low it will just die.
Also i've read somewhere a faulty coolant temp sensor giving incorrect readsing could screw with your idle. I didn't swap the KA sensor with the SR sensor since my friend sort of broke it. Could this be causing my problem?
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 10-16-2004, 10:26 AM   #2
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
Good luck with everyting! Post some pics up. This Winter ill be working on mine. Hope everything goes well.
Drift Indy
Edgar is offline   Reply With Quote
Old 10-16-2004, 12:55 PM   #3
Andrew Bohan
that sounds a lot like what my car was doing. i had a bad mafs and i swapped coolant temp sensors just for fun. try turning up the idle a bit too. i also have safc and boosting the fuel helped a bunch. good luck.
Old 10-16-2004, 03:01 PM   #4
statik
statik's Avatar
booooooost leak. my god damn BOV was leaking like woah, i slapped in a solid pipe and the car runs MINT. only problem is i dont want to boost till I get a new BOV cause im afraid ill fuck up the turbo, i heard running a little boost without a BOV will be OK. I have TONS of pictures I will be posting soon. Anyone selling a HKS BOV =]
Old 10-16-2004, 04:26 PM   #5
97SilviaRB
97SilviaRB is an unknown quantity at this point
Get a BOV asap dude.
97SilviaRB is offline   Reply With Quote
Old 10-16-2004, 05:00 PM   #6
statik
statik's Avatar
i know! im ordering one tomorrow, i need to drive it to work so i just wont boost i guess, not much i can do right now =\
Old 10-16-2004, 05:24 PM   #7
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
You NEED a ka temp sensor if you want your gauge to read properly. Also its safe to run no bov as long as you dont boost over 6psi.
TokyoNights is offline   Reply With Quote
Old 10-16-2004, 05:29 PM   #8
statik
statik's Avatar
Im aware of that, as I said my friend broke mine so I have to wait to get one on monday. Ill just try to avoid boosting as much as possible heh, hopefully should have a new BOV by middle of next week...
Old 10-16-2004, 11:38 PM   #9
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
i have no idea what kind of hot pipe your using but maybe you could use a DSM BOV or a supra one or somthing from a junkyard unless your getting your BOV soon...
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 10-17-2004, 12:13 AM   #10
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
DSM BOVs are junk... my friend had to crush his just so it would hold 7psi, and I think it was still leaking.
http://www.atpturbo.com/
bomb-ass BOVs yo.
statik: How did you mess up the MAFS wiring?
kazuo is offline   Reply With Quote
Old 10-17-2004, 04:24 PM   #11
statik
statik's Avatar
it was dark =]
Old 10-18-2004, 01:18 AM   #12
kazuo
Originally Posted by statik
it was dark =]
Nono, I mean like WHAT did you do to the wiring that messed it up?
Old 10-18-2004, 04:15 AM   #13
statik
statik's Avatar
wired the ground to maf signal wire heh, i know what you meant, that was funnier
