11-30-2014, 07:40 PM | #1 |
86 z31 Glitter Bombed drift build
Hey guys the name is Cameron and this is my 86 nissan 300zx thats slowly migrating its way to becoming a full track car*
List of useless crap I have done -1uzfe swap(not quite done, just finishing up my oil pan, wiring and odds and ends) -350z 6speed -Collins adapter z33 and 240sx trans adapter -Collins pilot bearing adapter -lengthened throwout bearing hub(did it myself) -custom 1uz flywheel -Southbend clutch and pressure plate rated for 420rwtq -Custom all aluminum rear sump baffled oil pan(I made) -working on installing a full cage -Sparco circuit race seat -Grip Royal steering wheel with NRG quick release -S13 rearend swap -SPL rear control arms(RUCAs, traction, toe) -z32 rear aluminum uprights with poly bushings -Mazworx weld in diff plate -q45 vlsd -Stance Pro SS-D coils with 12k swift springs -Extended 40mm FLCAs -Modded angle knuckles -3" blast pipe exhaust -XXR 521 18x10 wheels all around -custom engine and trans mounts(I made) -and to top it all off stupid flake bassboat paint job. Im pretty sure im forgetting things but its ok Few shots of the car before I started the swap Few shots during swap I will have more pics soon as I near completion on the car, I really dont have too much left but its getting there. I literally have to finish exhaust, oil pan and wiring and im ready to go |
04-01-2015, 09:46 PM | #4 |
Here you go, decided to get a few parts powdercoated, made some dual 3.5" blast pipes and a exhaust, made some oil filter relocation lines and stuff, tidying up the wiring now, putting in my new black interior, and cleaning stuff up
04-26-2015, 02:04 PM | #8 |
z31's look soo good when the suspension sits right, i might consider picking one up some day and putting a v8 in it like yourself. cool ride, sounds like a beast and it looks pretty sharp for a bass boat
09-18-2015, 10:27 AM | #16 |
So after driving the car for a bit and having fun I decided it needed to be faster, so no better way to do this than turbo, aftermarket ems and other corresponding mods. More to come as Im about to build the hotside
09-21-2015, 08:44 PM | #17 |
Finally got the turbo in place now I just have to start on the hotside. Also decided to cut some more shit out and do a v-mount rad/intercooler setup to make plumbing and such easier
09-26-2015, 09:40 AM | #19 |
Thanks, after I finish the hotside and other parts, then I can start my cage and rear structure for my fuel cell and battery, then after that repaint with a bunch of flake again and paint the interior and engine bay with a lot of flake also haha
10-13-2015, 07:56 PM | #20 |
its slowly getting there, dont mind the mig tacs, they were just for easy of mock up, and will get ground down and fully tig welded. Just have to wait on my flex pipe and wastegate parts, also ordered an intercooler core and some aluminum tubing. Should deff start coming together more over the next week
01-03-2016, 09:45 PM | #25 |
Lately I have been too busy with work, but I will snap some pics of what I have done. I decided to ditch the vmount setup, flipped the radiator around and did a traditional front mount intercooler setup. I will get pics as soon as I can get up to my shop
02-10-2016, 08:44 PM | #29 |
Thats because the cage is sitting on blocks of wood and not in its final location. With the boxes it will go up about anther 1.5 to 2 inches. They still might be a little lower than a slick top car only because I have to be able to still get my ttops off
04-11-2016, 07:55 PM | #30 |
I did a little more work on the car, since my setup up front was not working so well and I didnt want everything to be cramped up front I decided to move some stuff out back.
I still have a lot of work to go but its a slow process with how much I work, still waiting my my fuel cell and battery, and I still have to cut and form my new lexan quarter and hatch windows with NACA ducts and other proper ducting. |
