Old 11-23-2014, 07:22 PM   #1
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
what causes knock sensors to fail?
I know they are sensitive when it comes to dropping and that dropping one will most likely render it useless, but what, other than dropping one causes it to fail?
Can one that has sat for a couple of months "ruin" it?
I ask because when ever i first got my sr swap running and hooked up to consult, i had a code 34.
Replaced the sensor and didn't see the code 34 again.
Removed engine to do some shit and it sat for 2 months.
Put engine back in and I'm now getting a code 34 again.
Ive already bought a new sub harness and getting a new knock sensor as well. Should both be here this week
Im only asking because I'm curious.
Javi802 is offline   Reply With Quote
Old 11-23-2014, 11:17 PM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
I would say in a normal circumstance heat would be its main wear factor..
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 11-26-2014, 04:23 PM   #3
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Did you ONLY get a knock sensor code?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 11-26-2014, 04:58 PM   #4
Javi802
Javi802's Avatar
Yessir, thats the only code being thrown
Old 11-27-2014, 07:20 AM   #5
S14DB
AFC #1
S14DB's Avatar
Heat and Impact are the major ones. Rare case if you over Tq it you can deform it.
I see just as many Harness issues as the Sensor.
Old 11-27-2014, 09:33 AM   #6
Javi802
Javi802's Avatar
Well my engine never gets over even 180 degrees so i don't think heat is my issue.
Im hoping its just the harness. Being as the sensor i have is like 5 months old.
Im replacing both either way though sometime this week
Old 12-02-2014, 02:15 PM   #7
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Do you have a loose exhaust? Noises from a loose exhaust can sometimes throw a knock sensor code.
godsmack is offline   Reply With Quote
Old 12-02-2014, 04:01 PM   #8
Javi802
Javi802's Avatar
Yes, actually i do. Im running an open down pipe with a "fabbed" L bracket that connects it to the tranny mount. It was pretty loose.
In fact today while driving, it came loose and started dragging and making a clonking noise. Freaked me the fuck out, thought my car started knocking until i pulled over and looked underneath.
I replaced my sensor and sub harness today though and reset the ecu. Went for a little drive around the area and rechecked the codes and still a 55.
I noticed the previous sensor wasn't clipped in to the harness all the way though. I could actually wiggle it. I believe i bent the little metal clip that holds it in when i previously replaced the sensor. Maybe it wasn't making a proper connection..? Who knows.
Old 12-02-2014, 04:29 PM   #9
Kingtal0n
Kingtal0n's Avatar
some engines sit for 8-10 years on a shelf from Japan before they find owners. And they usually fire up no problem.
Its always scary the first time you turn it over though.
fwiw- never had a knock sensor go bad on an sr20det.
Old 12-02-2014, 04:48 PM   #10
Javi802
Javi802's Avatar
Hmm.
Guess its a waiting game now to see if a code 34 comes back. Hoping it doesn't
