![]() Join Date: May 2013
![]() Part List Rb25/S2 01/18/14 #006
Series 2 RB25DET Block (0 Miles) -Honed and Hot Tanked -Over $1,000 in Polydyn oil shedding and friction coatings (Block, Pistons, Timing gears, etc.) -ACL Bearings Main/Rod -ARP Main Studs -ARP Rod Bolts -10an Block Fittings -New OEM oil pan w/10AN Bung -New oil pump (Clearanced for High rpms) -New water pump -Rb26 water pump pulley(Remove if not installing aftermarket alt setup) -ARP Head Studs -3 Angle Valve Job W/new seals -HKS Step 1 Cams -Cometic head gasket -Tomei Oil Restrictor -Head Drain kit -Ngk Spark Plugs -Nismo Timing Belt (Run Time Previous build) -New Timing Belt Tensioner -Cometic Gasket Kit -Raw Brokerage Exhaust Stud Kit -Raw Brokerage Oil Filter Stud -Raw Brokerage Turbo AN Fittings OIL/WATER -PBM Filter Adapter -OEM Thermastat All Parts Have 0 Miles, Torqued to spec per Manufacture requirements. Engine Work Done by Power Fab Houston, TX Price is set at 3600 SHIPPED within the intercontinental US, FEES INCLUDED! questions, pm me, or text me 3126369394 |
![]() Join Date: Jan 2010
![]() ![]() ![]() ![]() Feedback Score: 10 reviews
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
to be honest, they both serve the same function, preventing excessive buildup of oil in the head. Both of them serve the same purpose . Have a nice day everyone. Bump!
UMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnNO!!!
the crank collar is needed because the contact area on the oil pump needs to be increased or you will have a oil pump failure during high rpms!!! 2 totally different issues, not busting ur balls but please be informed! good day!
![]() Join Date: Aug 2005
Trader Rating: (18)
![]() Feedback Score: 18 reviews
Nice buildup of the engine but yes totally different issues going on there buyer would have to tear it all down again to get the crank machined for the collar then this engine will be totally legit glws
DON'T BE UPSET WITH THE RESULTS YOU GET FROM THE WORK YOU DIDN'T DO. |
#17 |
![]() Join Date: Mar 2012
What compression is the pistons and brand of Pistons and rods
www.j2fastmotorsports.com |
#19 |
That's pretty pricey for oem motor without the crank collar
#20 |
Pictures of the work done and the final "as shipped" product would be helpful to your sale.
Technically, the crank collar mod is to defeat the issue of oil pump gear damage. Since the OEM collar does not fully cover the whole surface area of the oil pump drive and there is play, abrupt motion (i.e. clutch kicks, instant accelearation, etc.) will hit the drive on the oil pump and weaken it eventually causing it to crack and no longer function. Installing oil restrictors does not fix the crank collar issue and if he has a head drain kit, restrictors would be doing more than what is necessary. On top of that, restrictors won't necessarily fix issues with the RB. If you don't know how to set it up, you might cause more problems. He should have done a crank collar, but running no aftermarket restrictors on this build is perfectly fine.
#22 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
I decided on no restricter and I blocked one oil port on the block. Crank collar with spool import gears and I'm seeing 8 bar pressure with about 15w40. That's on break in
built, longblock, motor, rb25, rb26 |
