Old 11-01-2004, 10:06 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
Head Removal
How hard is it to remove the head on a 96 ka24de, and is it worth attempting while in the car. or would I be better off just replacing the whole engine instead.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 11-02-2004, 02:01 AM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
it can be done... ive done it on my 93 dohc while it was still in my car...a little time consuming but possible... but if you could find a better engine for a good price i would just go that way...
s13silady is offline   Reply With Quote
Old 11-02-2004, 03:11 AM   #3
Dweezil
Dweezil is an unknown quantity at this point
Just do the head, why waste the time and money on pulling the engine unless the short block is bad, or your doing a swap.
Originally Posted by tah
I would buy myself breast implants so I could play with some titties without getting slapped.
Dweezil is offline   Reply With Quote
Old 11-02-2004, 06:51 AM   #4
Mr. Spool
I have another head, it is a 96 ka head going on a 91 ka block. What kind of skill does it take to swap it out and about how long am I looking at for the swap.
I have done an engine swap, tranny swap, and turbo installs, but have never opened up an engine before. thanks.
96' SE Turbo'd
Old 11-02-2004, 11:10 AM   #5
Andrew Bohan
i would be more concerned about the wiring modification involved in going from external coil (s13) to internal coil (s14)
Old 11-02-2004, 12:40 PM   #6
Mr. Spool
on the distributor, I am doing that right now with no problems. I am going to go back to an s14 head.
96' SE Turbo'd
Old 11-02-2004, 01:09 PM   #7
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
just remember where stuff is supposed to go, other than that its not all that hard, I had to pull the heads off of an '88 4runner v6, took about a day to get it all apart and a week to put it all back on, but I never had an entire day to work on it,
just make sure you set aside enough time to actually work on the car and don't give up.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 11-02-2004, 01:16 PM   #8
Mr. Spool
do I have to resurface the head or just replace the gasket. also is there anything I should do to the inside of the engine in the process or just swap them.
thanks.
96' SE Turbo'd
Old 11-02-2004, 01:25 PM   #9
theicecreamdan
if you blew the headgasket you will want to check and make sure that the block didnt warp any... I think you just use a straight edge and make sure there aren't any gaps, but I'm not 100% on that process, I think it is described in most haynes/chilton's type manuals.
Old 11-02-2004, 09:25 PM   #10
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
You don't need to custom wire anything for the distributor. Just swap the distributor from your '91 and it will work.
Pacman is offline   Reply With Quote
Old 11-02-2004, 10:29 PM   #11
Mr. Spool
will a compression test tell me if the head is good or just the block. thanks
96' SE Turbo'd
Old 11-02-2004, 10:43 PM   #12
tErbo b00st
tErbo b00st is an unknown quantity at this point
Compression test will tell you if you have a blown headgasket or blown rings.
tErbo b00st is offline   Reply With Quote
Old 11-02-2004, 10:48 PM   #13
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
ps: Or bent valves.
TheSnail is offline   Reply With Quote
Old 11-03-2004, 12:41 PM   #14
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
wow if you are about to work on pulling your head out while leaving the engine in the car prepare to have a sore back just from bending over. i don't know if you have a low car or not but if you do prepare to feel the wrath of a sore back 10x worse!!!
I would just somewhat rebuild and make the ngine slightly buffer, repalce some gaskets etc. If i were to decide to pull the engine apart, might as well while your at it.
MasterOFDrift is offline   Reply With Quote
Old 11-03-2004, 03:47 PM   #15
Mr. Spool
Does anybody have an estimate of how long a head swap will take?
96' SE Turbo'd
Old 11-03-2004, 03:56 PM   #16
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
you can do it in 10 hours i guess.
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
