Old 11-03-2004, 11:38 PM   #1
prelude180
prelude180 is an unknown quantity at this point
Quick BOV question?
I'm a little bit confused. What is the benfit of an atomosphric blow off valve if every time it goes off, you loose boost? A recirculating bov still lets you keep some boost. There has to be another benefit besides the audio aspect. Also, in order to run an atmospheric bov, do you need to convert to a MAP sensor?
prelude180 is offline   Reply With Quote
Old 11-04-2004, 12:38 AM   #2
ALTRNTV
When you run atmospheric, all the air is being released to the outside. As that's happening, fuel is added into the engine without that air being combusted with the gas. That makes your car run rich, and you lose MPG that way. It also makes some cars stall because of the uneven mixture.
When you run re-circulated, instead of the air being vented to the outside, it goes back into the intake tube. Save more gas that way, and your car doesn't stall. You still get the BOV sound, but not as loud.
ALTRNTV is offline   Reply With Quote
Old 11-04-2004, 06:27 AM   #3
Frappe
Frappe's Avatar
Frappe is an unknown quantity at this point
Send a message via AIM to Frappe Send a message via Yahoo to Frappe
Is that to imply that there is not a benefit?
I'm curious about this too. Is there a benefit to atmospheric in certain situations/applications?
(sold) '96 S14b
Zenki4ever
Frappe is offline   Reply With Quote
Old 11-04-2004, 09:57 AM   #4
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
iirc, there isnt really any good things to having an atmospheric blow off valve besides the sound...you run rich after every shift, so if your car is rich already then you will backfire... you'll more likely to leak boost, you might stall out because of the lost air, and your turbo lag will increase..
s13silady is offline   Reply With Quote
Old 11-04-2004, 11:08 AM   #5
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
you can run a blow-thru mafs or use the decel-air function on the safc if you really want to vent to atm. i was originally planning on doin that, but now just for simplicity and troubleshooting im gonna recirc.
skatanic28 is offline   Reply With Quote
Old 11-04-2004, 11:10 AM   #6
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
are there only certain bov's that can recirculate? or is it all of them with the necessary equipment?
KoukiMonster is offline   Reply With Quote
Old 11-04-2004, 11:18 AM   #7
prelude180
Maybe I'm wrong, but isnt the recirulate just postponing the problem. The whole point of the bov is let out air so the turbo isnt boosting into a closed throttle. But the recirculate is sent back into the intake before the trottle. So if your turbo is spinnnig really fast, you still have the same problem, because it is pushing more air into a space closed off by the throttle, the recircualte is just adding a little more space, but not elimnating the problem? Am I misunderstanding something here?
Also is there any benefit to switching over to a MAP sensor and then running atmohperic BOV? Is this more benefical then say running a MAS with a recirculate BOV?
Old 11-04-2004, 11:40 AM   #8
KoukiMonster
well we run a maf so its beneficial to recirc.
Old 11-04-2004, 12:12 PM   #9
prelude180
yes, but I was wondering if there are any major benefits to converting over to a MAP sensor and using an atmospheric bov, compared to the regular recirculate/ MAS sensor setup?
Old 11-04-2004, 01:00 PM   #10
Distorted
Distorted is an unknown quantity at this point
Send a message via AIM to Distorted
MAF sensors as you know run off air, so logically if there ins't a continuous volume of air, you have a problem. Using a BOV with a MAF frequently harms your car's performace on the whole. A MAP sensor runs off pressure, so regardless of the volume of air as long as there is till pressure, you're car runs fine. This is grossly simplified but i'm not qualified to teach a physics class. think of it this way, you vent air on a MAF system and the car goes "where the fuck is the air, shit, give it fuel to keep it going." So you backfire and it sounds cool and the BOV goes "FOOOOSH" and you're happy, but slowly your hurting your motor and in turn your walet. Now think of a MAP system (this is where my turbo/na honda experience is great), if you vent to the atmosphere, it means nothing to the engine computer, it has no idea what air volume is, it just knows pressure. Your car runs fine, and IMHO is easier to tune because you can go off fine pressure adjustments and compensate very easily for density, but thats just the bulk of my personal experience speaking.
The main answer to your questions is IF you switch to a MAP system, and i CAN be done its just tricky or expensive, you can vent to the atmopshere. If you keep a MAF system, it's better to use a reciculating system. If the sound matters that much to someone, let them vent, if performance is their true concern then they should recirculate. AND almost all BOV's can be adapted or are designed to be used for recirculating, it just means you add a pipe.
Distorted is offline   Reply With Quote
Old 11-04-2004, 02:01 PM   #11
tErbo b00st
tErbo b00st is an unknown quantity at this point
Most people have the general idea but here is really what happens...
The advantage to venting the the atmosphere is that you are getting rid of the hot air in the intake tract. when you recirculate it usually gets recirculated back before the turbo, this air is hotter than ambiant air because it has already been compressed and run through the engine bay. Then you put it back in and it gets recompressed and gets even hotter. As you should know, hot air is an enemy.
Now the disadvantage to running atm is when you are running a suck through MAF. Your MAF reads a certain amount of air going into the intake and records it in the ECU and uses this amount/temp of air to calibrate how much fuel to put in. When you vent the air goes bye bye, but the ECU doesnt know about this change. So it thinks that there is x amount of air and injects enough fuel to run correctly, but the air is not there so too much fuel is injected, aka u run rich. This is where the backfiring comes from because the unburnt gas goes out the exhaust valves and into the exhaust where it puddles up and gets heated enough where it explodes in the exhaust.
Two ways to counter this (AFC settings ect, just make things better. You cant actually fix it). Either change to a blow through MAF, or a MAP sensor. With a blow through you basically just move the position of the MAF to after the BOV. So the air that gets vented never actually gets registered by the ECU because it is gone before the MAF sees it. MAP sensor works pretty much the same way (in this case). The MAP sensor is generally located in the intake Mani or TB and so it senses the air actually going into the manifold, so any air that gets vented isnt registered. The fact that it registers pressure as opposed to amount of air doesnt really matter (as far as I know).
And yes only certain BOVs can be recir. Most can, but certain ones such as race BOV (Greddy, HKS, ect) and Tial BOV.
So there isnt a Huge advantage, except the sound and the small performance gain you get by not recirc. the hot air. But the more boost you run the hotter the air gets, hence why most high HP cars vent to the Atm.
And that concludes todays class.
tErbo b00st is offline   Reply With Quote
Old 11-04-2004, 02:10 PM   #12
timmybgood
timmybgood is an unknown quantity at this point
i have absolutly no stallng issues with my atmosphere bov. occasional backfires though
1995 SE
timmybgood is offline   Reply With Quote
Old 11-04-2004, 04:30 PM   #13
prelude180
How difficult is it to convert to MAP sensor. I know apexi sells a kit for converting, when you pruchase a D-jetro Pfc. Also is it good/bad idea to move MAF sensor after the BOV?
