Old 06-04-2015, 11:29 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
S13 SOHC stock parts, MORE PARTS!
2 S13 SOHC distributors
These are good working condition S13 SOHC distributors. Both came out of running cars with no issues.
$30ea
KA24E fuel injectors
These are 7 KA24E (sohc) fuel injectors. All 7 test good electrically and came off good running engines.
$20ea
SOHC power steering tensioner
This is a good condition SOHC power steering belt tensioner. The pulley is undamaged, the bearing is nice and smooth, and the adjuster works perfectly.
$15
SOHC water pump pulley
This is a good condition SOHC water pump pulley, no damage.
$10
SOHC fan/clutch
This is a SOHC complete clutch fan. The fan blades have very minimal cracking and the clutch is still good. It's just a little dirty.
$25
SOHC exhaust mani w/heatshield
This is a good condition SOHC exhaust mani with the heat shield. No cracks or damage of any kind and the mani does not have any bolts broken off in it or broken studs.
$25
SOHC distributor cover
This is the cover that goes over the distributor on a SOHC KA. You hardly ever see these still on the cars and it adds a bit of a cleaner look to the plug wires. I have two of these...
$10
SOHC crank pulley
Good condition, no damage, not rusty.
$20
SOHC ignition coil
This is a SOHC ignition coil with the bracket and WITHOUT the igniter. Came off a running/driving car, no issues. I also have another with the ignitor for $20.
$10
SOHC MAF sensor
This is a good, working SOHC MAF sensor with a 3 pin connector. Came off a 100% running/driving car, 100% FOR SURE good. I will clean the MAF element before pick-up/shipping with MAF sensor cleaner.
$25
2 SOHC M/T ECU's
This is an ecu for SOHC, M/T, CA emissions. I have 2 of these. 100% for sure good, came off running cars.
$25
One SOLD, One Left
SOHC plug wire set
This is a used, but recently replaced, complete set of SOHC plug wires. The wires are good quality, no loose boots, no pulled out connectors.
$10
SOHC NGK plug wire set
This is a full set of NGK wires for a SOHC KA. The wires are in good condition, no misfires, corrosion, or damage.
$20
SOHC intake air temp sensor
This is a good working condition SOHC air temp sensor. It mounts in the airbox on SOHC cars.
$10
SOHC P/S lines
This is a complete set of S13 SOHC P/S lines. The pressure hose was replaced about 2 years ago. No leaks, no damage, just dirty from a leaky engine.
$40
S13 stock downpipe
This is the stock downpipe from a SOHC KA, but will work on DOHC as well. No damage, the heat shield was removed because it was rattling.
$15
SOHC complete intake mani/sensors
This is a complete intake mani assembly with all the sensors. I am parting this out so PM me with what you need and we can work out a price.
$offer$
SOHC engine partout
This is a mostly complete SOHC engine. The engine ran great when removed, passed smog no problem, but has 283k on it and was burning oil. The TPS was recently replaced with a new OE unit. The engine is SUPER clean inside, all maintenance done, synthetic oil only. The wiring harness is there, but the ECU, intake, and crank pulley are listed in a separate thread as they are aftermarket. It would be a good candidate if you planned on building it. PM me with what you need and we can work out a price from there.
$offer$
Old 06-05-2015, 07:32 PM   #2
racepar1
racepar1's Avatar
Bump........
Old 06-08-2015, 09:17 PM   #3
racepar1
racepar1's Avatar
Bump........
Old 06-12-2015, 09:03 PM   #4
racepar1
racepar1's Avatar
Bump........
Old 06-15-2015, 01:12 AM   #5
royalsociety94
royalsociety94 is an unknown quantity at this point
How much for the iacv sensor with the hoses for it and do u still have the wiring harness and if so how is it and how much for it?
royalsociety94 is offline   Reply With Quote
Old 06-15-2015, 10:47 PM   #6
racepar1
racepar1's Avatar
If you guys want anything you'd better act fast! This stuff will all be in the hands of the local scrap guy come next week...
Old 06-16-2015, 01:48 AM   #7
240_Sotelox
240_Sotelox is an unknown quantity at this point
Do you still have ecu and harness?
240_Sotelox is offline   Reply With Quote
Old 06-16-2015, 08:40 PM   #8
racepar1
racepar1's Avatar
Yes I do...
Old 06-18-2015, 08:06 PM   #9
240_Sotelox
40 for ecu and harness and maf?
Old 06-19-2015, 10:57 PM   #10
racepar1
racepar1's Avatar
Bump........
