Old 11-03-2004, 09:55 PM   #1
import_racer87
import_racer87 can only hope to improve
Prepping an sr20
95% of sr20s look like hell right after they have been purchased. who even knows where they have been. what exactly needs to be changed from when you purchase the motor, to when its ready to go into the car? im guessing the usual spark plugs, distributor, plugs, injectors, check the the rubber hoses, etc but heres where i see the dilemma. those engine have been sitting, non running for so long, i would think the intake mani. would be filled with dirt, the cylinders would be all gunked up and you couldnt just replace the stuff and fire it up because u'd end up with a fucked up new again. i could be wrong on this but give me your opinion.
import_racer87 is offline   Reply With Quote
Old 11-03-2004, 09:58 PM   #2
Dousan_PG
Dousan_PG's Avatar
filled w/ dirty? what the intake throttle body was left open?
definatley change to new thermostat and water pump
new clutch
all gaskets (you wont regret it--you will if you have to change them after the motor is in)
ALL fluids (duh)
replace as much as you can
and that includes a lot on your car too (fuel filter and so forth)
Aaron
Pink GodziRa
Old 11-03-2004, 09:58 PM   #3
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
I'd add to the list:
-Front main seal
-Rear main seal
-Thermostat
-Clean intake manifold
-On first oil change, run an engine cleaner (Motul Engine clean, seafoam, whatever)
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 11-03-2004, 10:01 PM   #4
Dweezil
Dweezil is an unknown quantity at this point
If your really worried, drop the oil pan and have a look at the internals. Get a FSM and measure bearing clearances if you think the motor has been beat on.
Originally Posted by tah
I would buy myself breast implants so I could play with some titties without getting slapped.
Dweezil is offline   Reply With Quote
Old 11-03-2004, 10:02 PM   #5
import_racer87
and i guess i could clean the im and tb with some throttle body cleaner, but people dont really bother with the cylinders at all? or is that not really an issue? there would be any negative affect from it being so dry in there for so long? (ie scratching the cylinders on the first start up becaue of lack of lubrication or debris)
Old 11-03-2004, 10:08 PM   #6
Dweezil
Use Seafoam or other engine cleaner to clean out any debris that is in there. If your worried about starting it dry, put a few (and I mean only a few) drops of oil in the cylinders, pull the fuel pump fuse and crank the motor over a few times to lube it before you start it for the first time.
Old 11-03-2004, 10:16 PM   #7
import_racer87
ok, thats a good idea.
im basically just trying to get a read from you guys on if worrying about the cylinders is a legitimate concern, or would it just be a paranoid thing to do. would you guys worry about if (or when you did) you were swapping an sr into your car? would a professional shop who was installing it worry about it?
Old 11-03-2004, 10:24 PM   #8
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
http://www.store.yahoo.com/phase2mot...0detinpar.html
fuel filter
check if the clutch fan is in good shape, if not go with electric fan.
KoukiMonster is offline   Reply With Quote
Old 11-04-2004, 02:31 PM   #9
sLiDewAys
sLiDewAys is an unknown quantity at this point
yeah, i agree
-front main seal
-rear main seal
-headgastket
-(PROFESSIONAL) head cleaning
-Clutch
-Resurface flywheel
-Oil Pan
thats what i'd do if i were to purchase sr motorset or clip, but i house ca18 so i did a little more./
sLiDewAys is offline   Reply With Quote
Old 11-04-2004, 03:04 PM   #10
the head
the head's Avatar
Location: in a dark room mastering the art of typing with one hand
the head is making a name for him/her selfthe head is making a name for him/her self
when i put mine in
plugs
o2
belts
all fluids
cleaned TB and intake mani
Seafoam
I didnot worry about gaskets as i had a low milage clip
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 11-04-2004, 06:32 PM   #11
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
now you don't HAVE to replace waterpump, i have 4 friends w/ srs who have ran their car on the original waterpump for 2 years,
-Ditch the clutch fan
-Check plugs before u change them
-New fuel filter
-Check FPR
-Check knock sensor, (the brass metal on the back if it is discolored like purple or green its blown)
-Check compression
-Check turbo
-Make sure gasket between turbo and xhaust manifold r good,
The main thing is to get the $200 gasket kit, i wish i had done that, do all those gaskets and clean every part it would be the cleanest stock sr imaginable.
sepulchral is offline   Reply With Quote
Old 11-04-2004, 06:35 PM   #12
sepulchral
WHEN YOU DO THE SWAP, HIDE THE DAMN HEATER HOSE!!!
not a clean swap if u can see the heater hose
OH yes and....
SAUDER EVERY CONNECTION!
Old 11-04-2004, 07:05 PM   #13
KoukiMonster
and where do you obtain this gasket kit dude.
just for future reference of this thread for other ppl
Old 11-04-2004, 07:39 PM   #14
import_racer87
thanks for all the help guys, you really covered a lot. so i guess cylinder wise (the only thing im still unsure about) the seafoam treatment is done AFTER the engine is installed and running? then get a compression test, and if im worried on the first start up just give it a few drops of oil. does this sound like all that really needs to be done with the cylinders or am i leaving something out?
Old 11-04-2004, 09:22 PM   #15
sepulchral
http://store.240sxmotoring.com/srfugakit.html
full gasket kit, this is kinda expensive, theres another site that has it cheaper but u gotta do a search.
Old 11-04-2004, 10:42 PM   #16
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
most important part, before cranking it up to start, crank it over with ignition components disconnected to prime up your oil system. those bearings need oil before u run it.
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 11-04-2004, 10:53 PM   #17
Dweezil
someone should archive this soon. Would probebly save tons of questions later.
Old 11-04-2004, 11:34 PM   #18
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
oh come on, if your going to take all that time to make sauder so big and colorfull atleast spell it right =P
solder my friend
wootwoot is offline   Reply With Quote
Old 11-05-2004, 05:19 AM   #19
sepulchral
haha
lol woops...............
