Old 06-03-2015, 04:03 PM   #1
SofaKingFast
Trader Rating: (43)
SofaKingFast is an unknown quantity at this point
Feedback Score: 43 reviews
Send a message via AIM to SofaKingFast
s14 HUGE S14 + SR20 Partout, tons of quality parts (KW, SPL, PBM, Nismo)
Hey everyone,
I didn't have much luck selling the car as a whole, so regrettably i've started the part out process. All prices below are OBO, so feel free to shoot me offers. Shipping is available at buyers expense.
EDIT 6/10/2015: DEPOSIT ON LONG BLOCK HAS BEEN TAKEN. ALL PARTS ARE NOW AVAILABLE FOR PURCHASE!
All other parts are currently on the car, and will be removed immediately after purchase. For fastest response please PM me. If you would like additional pictures, please include your cell number.
ENGINE
BRM/magnaflow dual exhaust $250.00
Silicon radiator hoses $50.00
Nismo thermostat $75.00
Manual Boost Controller (polished) $50.00
Megan polished alt/water pump/ps pulleys $60.00
AEM/GM 3 bar map sensor
AEM IAT sensor
Drift freaq motor mounts $100.00
Drift freaq transmission mount $120.00
Wiring Specialties harness (S13 SR into S14, SARD injectors, MAP, IAT) $200.00
CX racing FMIC $180.00
Tomei Oil Cap $30.00
Kazama Oil Catch can (can only braided lines extra) $100.00
Walboro 255 in tank fuel pump $50.00
Circuit Sports AFPR w/ gauge $60.00
Polished valve cover $150.00
TURBO KIT
Comp turbo triple ball bearing turbo, vband exhaust housing $1,200.00
Tial 38mm external wastegate w/ upgraded spring $140.00
2000 degree heat treated PeakBoost exhaust manifold $600.00
Custom 2000 heat treated turbo dump and downpipe (vband) $200.00
SS Braided turbo oil feed $40.00
Braided turbo oil drain $20.00
SUSPENSION/BRAKES
5 lug rear hubs w/ like new bearings all around $150.00
Z32 ebrake assembly $140.00
Brake booster (this is the larger automatic version) $50.00
Tein front camber plates DEPOSIT TAKEN
KW V3 Coilovers DEPOSIT TAKEN
Megan rear strut tower bar $50.00
Rear pillar bar $50.00
Circuit Sports rear subframe inserts $50.00
Rear subframe PENDING
Cluster w/ white LED's $60.00
Infiniti polished door handles $20.00
Nismo titanium shift knob $100.00
S14 front spindles $120.00
INTERIOR
Pioneer 6.5" front speakers $50.00
brake, accelerator pedal $50.00 EA
Works Bell Steering wheel $140
EXTERIOR
China brand HID kit* $40.00
Thanks for looking!
Ryan
SofaKingFast is offline   Reply With Quote
Old 06-03-2015, 04:26 PM   #2
solow240
solow240 is an unknown quantity at this point
Interested in the wiring specialties harness. S13 sr to s14 chassis?
solow240 is offline   Reply With Quote
Old 06-03-2015, 04:39 PM   #3
SofaKingFast
Trader Rating: (43)
@Solow240 yes its for an S13 SR to S14 chassis harness. Note that the harness has additional wiring added for the AEM IAT and MAP sensor, so if you're running a MAF you'd need a different one.
Old 06-03-2015, 04:56 PM   #4
OZELKOUKI97
Banned from the Marketplace
OZELKOUKI97 is an unknown quantity at this point
Originally Posted by sofakingfast View Post
hey everyone,
i didn't have much luck selling the car as a whole, so regrettably i've started the part out process. All prices below are obo, so feel free to shoot me offers. Shipping is available at buyers expense. The motor is still currently in the car and it starts and runs. I'll be keeping it that way until i can find a buyer for the long block, which means the parts listed under the title "available after motor sells" aren't yet available. All other parts are currently on the car, and will be removed immediately after purchase. For fastest response please pm me. If you would like additional pictures, please include your cell number.
long block
fully built s13 sr20det long block $2500.00
- cp pistons
- eagle rods
- acl bearings
- block was bored/honed/hot tanked
- all new gaskets
- metal head gasket
- full head job
- tomei pon cams (256/256)
- arp head studs
aem v2 ems w/ map and iat sensor upgrade $1,300.00
drift freaq motor mounts $100.00
drift freaq transmission mount $120.00
comp turbo triple ball bearing turbo, vband exhaust housing $1,200.00
tial 38mm external wastegate w/ upgraded spring $140.00
2000 degree heat treated peakboost exhaust manifold $600.00
sard 850cc injectors $300.00
wiring specialties harness $200.00
freddy manifold (decked and port matched) $100.00
cx racing fmic $180.00
greddy type r bov $120.00
tomei oil cap $30.00
kazama oil catch can $100.00
circuit sports oil filter relocation kit $75.00
walboro 255 in tank fuel pump $50.00
circuit sports afpr w/ gauge $60.00
megan test pipe $40.00
custom 2000 heat treated turbo dump and downpipe (vband) $200.00
polished valve cover $150.00
ss braided turbo oil feed $40.00
braided turbo oil drain $20.00
engine
dif water temp sensor fitting $40.00
griffin radiator $350.00
gktech fan upgrade $80.00
oem fan shroud for proper cooling $15.00
chase bays power steering reservoir and braided lines $200.00
brm/magnaflow dual exhaust $250.00
silicon radiator hoses $50.00
nismo thermostat $75.00
suspension/brakes
bmc heat shield wrapped in gold heat wrap $40.00
chase bays brake hardline delete kit $100.00
5 lug hubs w/ like new bearings all around $300.00
brake booster (this is the larger automatic version) $50.00
nismo power brace $120.00
spl tension rods $180.00
spl ruca's $275.00
circuit sports rear toe arms $100.00
pbm traction arms $100.00
spl tie rod ends $180.00
tein z33 inner tie rods w/ spacers $70.00
tein front camber plates $90.00
kw v3 coilovers $1,300.00
circuit sports flca's $300.00
circuit sports sway bar end links $40.00
megan rear strut tower bar $50.00
rear pillar bar $50.00
steering rack w/ poly steering rack bushings $80.00
rebuilt j30 axles (5 bolt) $120.00
exedy clutch w/ lightened flywheel $150.00
nismo clutch slave $80.00
circuit sports rear subframe inserts $50.00
rear subframe $100.00
cluster w/ white led's $60.00
infiniti polished door handles $20.00
nismo titanium shift knob $100.00
b&m short shifter $150.00
interior
pioneer 6.5" front speakers $50.00
clutch, brake, accelerator pedal $50.00 ea
works bell steering wheel + boss hub $180.00
exterior
s14 kouki wing $225.00
aerocatch hood pins w/ lock $60.00
china brand hid kit* $40.00
thanks for looking!
Ryan
buddy pm me i need the kouki wing if you sell have them
OZELKOUKI97 is offline   Reply With Quote
Old 06-03-2015, 05:33 PM   #5
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
Hi, does the gktech fan come with the clutch part too? or just the fan?
@adrianfromthecastle
Old 06-03-2015, 11:31 PM   #6
jus10s13
jus10s13's Avatar
jus10s13 is making a name for him/her selfjus10s13 is making a name for him/her selfjus10s13 is making a name for him/her self
Seats available?
jus10s13 is offline   Reply With Quote
Old 06-04-2015, 04:01 AM   #7
solow240
You have a pm
Old 06-05-2015, 04:52 PM   #8
Clean98
Clean98 is an unknown quantity at this point
Ship subframe to 84056?
Clean98 is offline   Reply With Quote
Old 06-05-2015, 06:30 PM   #9
RJs9DsixS14
RJs9DsixS14's Avatar
RJs9DsixS14 is making his/her stupidity well-knownRJs9DsixS14 is making his/her stupidity well-knownRJs9DsixS14 is making his/her stupidity well-knownRJs9DsixS14 is making his/her stupidity well-known
Im really interested on the KW coilovers please txt me 626-252-0997
RJs9DsixS14 is offline   Reply With Quote
Old 06-05-2015, 08:49 PM   #10
kerrykerrykerry
kerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymorekerrykerrykerry is not welcome here anymore
Somebody buy the motor. I want that kazama catch can! :-)
kerrykerrykerry is offline   Reply With Quote
Old 06-06-2015, 01:21 AM   #11
that240sxguy
that240sxguy's Avatar
that240sxguy is an unknown quantity at this point
Are the headlights for sale? 7204682474
that240sxguy is offline   Reply With Quote
Old 06-07-2015, 03:21 AM   #12
jamesd
jamesd is an unknown quantity at this point
How much for front side markers ?
jamesd is offline   Reply With Quote
Old 06-07-2015, 07:40 AM   #13
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
$250 for the injectors? Let me know if and when. I call dibs lol
Javi802 is offline   Reply With Quote
Old 06-07-2015, 03:44 PM   #14
YOSHIKOUKI
YOSHIKOUKI's Avatar
YOSHIKOUKI is an unknown quantity at this point
Send a message via Yahoo to YOSHIKOUKI
I'll take the Freddy and oil filter relocation kit once its available
YOSHIKOUKI is offline   Reply With Quote
Old 06-08-2015, 12:30 AM   #15
jayy08
jayy08's Avatar
jayy08 is an unknown quantity at this point
do the z33 tie rods mount like stocks or any modifications needed?
jayy08 is offline   Reply With Quote
Old 06-08-2015, 07:44 PM   #16
Rich77
Rich77's Avatar
Rich77 is an unknown quantity at this point
PM sent.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Rich77 is offline   Reply With Quote
Old 06-09-2015, 01:12 PM   #17
SofaKingFast
Trader Rating: (43)
Jayy08 yes the tie rods mount just like stock, no modification is needed.
Updated the parts list as some of the things have been sold. Also i've been getting a lot of messages for the headlights, but those have been sold sorry!
Old 06-09-2015, 01:48 PM   #18
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
a lot of goodies here
Old 06-10-2015, 02:13 AM   #19
GenkiZenki808
GenkiZenki808 is an unknown quantity at this point
sell the amber bumper marker lamps?
GenkiZenki808 is offline   Reply With Quote
Old 06-10-2015, 02:44 AM   #20
MY_S14_SR20DET
MY_S14_SR20DET is an unknown quantity at this point
Sent you a PM like a week ago...
MY_S14_SR20DET is offline   Reply With Quote
Old 06-10-2015, 03:40 PM   #21
Rich77
Rich77's Avatar
Another PM sent
Old 06-10-2015, 05:23 PM   #22
ZenkiZenki14
ZenkiZenki14's Avatar
ZenkiZenki14 is an unknown quantity at this point
You selling the P/S pump?
ZenkiZenki14 is offline   Reply With Quote
Old 06-10-2015, 06:17 PM   #23
SofaKingFast
Trader Rating: (43)
Update! Deposit on the long block has been made, which means the rest of the items are up for sale now!
Old 06-10-2015, 06:53 PM   #24
Clean98
How much for the bare subframe?
Old 06-11-2015, 07:21 AM   #25
err
err is an unknown quantity at this point
are the headlights for sale?
err is offline   Reply With Quote
Old 06-15-2015, 01:54 AM   #26
SidewayzAsFck
SidewayzAsFck can only hope to improve
Interested in workbell steering wheel. Pics?
SidewayzAsFck is offline   Reply With Quote
Old 06-15-2015, 05:16 PM   #27
SofaKingFast
Trader Rating: (43)
All PM's replied and part availability updated. I have a ton of stock parts as well so if you guys need anything please PM me. Thanks!
Old 06-17-2015, 09:46 AM   #28
MegaFresh240
MegaFresh240's Avatar
MegaFresh240 is an unknown quantity at this point
Do you have s14 fuel pump w/ assembly
MegaFresh240 is offline   Reply With Quote
Old 06-17-2015, 03:55 PM   #29
SofaKingFast
Trader Rating: (43)
Sorry MegaFresh240 stock fuel pump sold. I do have a Walboro 255 though.
Old 06-17-2015, 07:52 PM   #30
Jibbberish
Jibbberish's Avatar
Jibbberish is an unknown quantity at this point
Interested in fan shroud if you still have it.
Jibbberish is offline   Reply With Quote
