![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
SOHC performance! JWT ECU, crank pulley, Injen intake
Jim Wolf ECU
This is a JWT ECU for a SOHC S13. I JUST pulled it out of my PERFECTLY running S13 so it has NO ISSUES. It is only tuned as an upgrade for the stock engine, but JWT can re-tune it for about $100. This would be perfect for someone building a turbo SOHC. Also, this is a federal ECU so it will not set an EGR DTC. As it is on a stockish engine it's still a very nice upgrade. Improved throttle response, a bit more power, and it still passes smog. SOLD! SOHC ASP crank pulley This is an ASP crank pulley for a SOHC KA. The pulley is in great shape, only small marks on the backside from removing it. It does underdrive the water pump and alternator. It is also sleeved for the crankshaft seal so it won't wear and leak. Altogether this is a REALLY nice pulley, I wish it worked on a dualcam... $60 ![]() SOHC Injen intake This is a COMPLETE Injen intake system for a SOHC KA. EVERYTHING you need is included, just bolt it in and go. Also included is a custom bracket if you do not have the stock fan shroud. You would need to get a rubber mounting bushing or put together a spacer arrangement to mount the bracket though as I re-used the mount bushing on my dualcam intake. $100 ![]() Last edited by racepar1; 06-09-2015 at 11:07 PM.. |
#11 | |
Will do... |
