Old 11-05-2004, 03:54 PM   #1
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
SR Boost problem spuddering
I have a Redtop with stock T25,370cc injectors.intake FMIC, i had the boost stock for a long time then i turn the boost up with a Manual turbo XS boost controller i couldnt run more than 10psi as normal , then i got a new fuel pump... problem is i dunno what fuel pump i have.... i was told it was for a 300zx TT then he said it was actully for a 3rd gen RX-7.. then pump is a lot better than my stock one..i dont have the power elay thing.. im not really sure what that is. its brand new i got it from a autoparts store... FREE. its a carter P72165.. sometime i can run 14 psi with no problem but it does spike really bad.. but after the engine warms up it wont run more than about 11psi with spuddering BAD... real odd thing is that even when i was running 12-13psi when its wasnt spuddering the car wasnt any fast at all... HELP!?!
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 11-05-2004, 09:56 PM   #2
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
1) manual boost controllers spike
2) The fuel pump does not affect the boost
3)You probably have a boost leak which causes sputtering, loss of power, loss of boost.
4) I would only stick with a nissan fuel pump, the autoparts store should give you the correct one and not lie and say its for a 300zxtt.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 11-06-2004, 02:06 PM   #3
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
you try checking gaskets, sparkplugs, or even the fuel filter?
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 11-07-2004, 03:06 PM   #4
s13dan
s13dan's Avatar
The auto parts store didrt lie, my friend that works there was mistaken either way it was free,and i know the fuel pump dosnt change the boost my turbo xs boost controller did that... the pump would have made it possible.. and tonight im ganna check those things...
