Old 07-26-2015, 02:36 AM   #1
dluevanos01
dluevanos01 is an unknown quantity at this point
S14 sr20 part out! Quality parts.
S14 sr20det part out!!
Engine has 30% leak on cylinders 2 & 3, so getting rid of everything SR related as if I decide to keep the car I won't be getting another one. Might prt out the rest of the car.
Specs:
Long lock: still need to take it apart and see what caused it. Leaking to crankcase.
-CP pistions 8.5:1 stock compression
-Eagle rods w/ ARP 2000 studs
-ACL Race rod and main bearing
-ARP head and main studs
-MLS headgasket
Other parts:
Everything is in perfect order as I verified everything before doing a leak down test.
-Tomei elbow (updated version) $140
-Moroso oversized baffled aluminum oil pan (one very small scratch on the bottom) $275
-Nismo engine/trans mounts (low miles/still firm) $250
-CodyAce Quest alternator and A/C brackets $200 (replaced alternator about 3 months ago)
-Z32 MAF( with extra pigtails) $85
-Mazworx chain tensioner $80
-Nismo 740CC injectors $500
-S15 T28 (GT28r) $650 (will include manifold/heat shield)
-Silicone radiator hoses $50
-RS-Enthalpy ROM tune $400 (tuned for their set up)
-DIF steel braided turbo lines with heat sleeves $100
-Nismo Sport Copper mix Clutch/flywheel $500
-Tomei Poncams 256/256 retains VTC $275
-Greddy RAS $50
-Ishihara Johnson teflon crankshaft scraper $80
-Wiring specialties s14 sr to s14 engine/ lower harness (modified by Eric Typner to go on s13) $350
If you need anything else engine related, pm me/comment for price.
Will make a more detailed post once engine is out and have it taken apart.
Inside pictures (extremly clean)
IG: @te37_daniel
Build thread
dluevanos01 is offline   Reply With Quote
Old 07-26-2015, 04:56 AM   #2
vjimmyv
vjimmyv is an unknown quantity at this point
how much for the starter?
vjimmyv is offline   Reply With Quote
Old 07-27-2015, 08:21 AM   #3
Cdawg240
Cdawg240 is an unknown quantity at this point
Fuel pressure regulator? And intercooler piping?
Cdawg240 is offline   Reply With Quote
Old 07-27-2015, 08:49 AM   #4
TheRealSy90
TheRealSy90's Avatar
Best price on the chain tensioner?
Such a good signature.
Old 07-28-2015, 07:07 PM   #5
mreid
mreid is an unknown quantity at this point
Block / crank / Cams and other stuff
Block / crank / Cams and other stuff - PM'd you my phone number...
mreid is offline   Reply With Quote
