Old 08-11-2015, 10:10 AM   #1
lovethatpssh
lovethatpssh is an unknown quantity at this point
Need help with shimmy at 45 mph
My 91 s13 drives fine until I get up to abt 45 mph then shakes really bad. Feels like its coming from the front but not sure. But the steering wheel shakes bad to at the same speed but below 45 it couldn't drive better help please
lovethatpssh is offline   Reply With Quote
Old 08-11-2015, 10:20 AM   #2
onehundredoctane
onehundredoctane's Avatar
Here is a short list of things to check.
-alignment
-wheel bearing
-axle nut on front hub
-wheel balance
-tie rod
Old 08-11-2015, 10:38 AM   #3
slider2828
slider2828's Avatar
front subframe bolt torque to spec.
Turn and Burn!
Old 08-11-2015, 10:57 AM   #4
Vell
Vell is an unknown quantity at this point
If it's shaking around 45 THEN it's fine around 50~55, it should be around your tires ... balance / deformation.
Vell is offline   Reply With Quote
Old 08-11-2015, 01:57 PM   #5
lovethatpssh
Yeah it does it around 45 then 50 it don't soo I'll check tht
Old 08-11-2015, 02:43 PM   #6
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Balance them bad boys.
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 08-11-2015, 07:33 PM   #7
dbeiler
dbeiler's Avatar
Check tension rod bushings.
