Old 11-14-2004, 07:55 PM   #1
DriftingXJDM
DriftingXJDM is an unknown quantity at this point
no pressure on clutch pedal...
I have a 91 240sx I replaced my slave because it started leaking until it gave out and I can't go to any gear at all. After I replaced the slave I vacuum bled it and pressure and the pedal goes straight to the floor so I replaced the master I thought probably just a bad master also but I bled it and everything still the same... help anyone is there some special thing I have to do???
DriftingXJDM is offline   Reply With Quote
Old 11-15-2004, 12:42 PM   #2
RiversideS13
RiversideS13's Avatar
RiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond repute
Send a message via AIM to RiversideS13
i think you didnt bleed it right? or maybe you put in wrong fluid??
RiversideS13 is offline   Reply With Quote
Old 11-15-2004, 01:54 PM   #3
dnomyar
dnomyar's Avatar
dnomyar is an unknown quantity at this point
do you still have the damper? you'll need to bleed it according to the FSM.
dnomyar is offline   Reply With Quote
Old 11-15-2004, 04:15 PM   #4
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
maybe ur master cylinder needs to be replaced. or maybe the o ring on the bottom of ur master is shot
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
