Old 11-16-2004, 08:21 PM   #1
psychedelicbeats
psychedelicbeats is an unknown quantity at this point
3 top transmission bolts (AT)
how did you take those out? i'm having a hard time taking it out for my 5 speed swap. i have a little honda jack between the tranny and the tranny well and it's pushing the tranny down good. i also have a jack on the engine itself so that when the bolts give way, the engine wont fly off. but how far do u go to take out the bolts? i'm jacking it to the point where the engine starts hitting the firewall and i'm still jacking, and i'm afraid that the engine mounts will get messed up because there's a lot of pressure on one side of the engine. any advice would help thanks
psychedelicbeats is offline   Reply With Quote
Old 11-16-2004, 09:02 PM   #2
SimpleS14
SimpleS14's Avatar
I had to lower the tranny to the point that the engine was hitting the firewall. Then I got underneath the car (jack up high enough) and used i think four 6" extentions (with rachet and socket) to get the very top bolt. Then I used a breaker bar or a pipe on a flex head wrench for the others.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 11-16-2004, 10:04 PM   #3
s13irdie2
s13irdie2 is on a distinguished road
i went from the top of the engine and used an extension and a breaker bar. its really easy with the right tools.
1990 s13
IslandMotorsports, Inc.
s13irdie2 is offline   Reply With Quote
Old 11-16-2004, 10:16 PM   #4
psychedelicbeats
top of hte engine, eh? so did u jack the tranny to tilt the engine forward?
Old 11-17-2004, 10:41 AM   #5
Luke
Luke is an unknown quantity at this point
Send a message via AIM to Luke
I had to drop the engine down a little but unbolting the 4 crossmember nuts from the body/frame of the car.(use a jack to support the bottom of the crossmember) There's 2 on each side, i had to do this to get the trans to clear the body to remove it, but it also helped tremendously to get at those top bolts.
'93 240sx Coupe
SR20DET Blacktop
Luke is offline   Reply With Quote
Old 11-17-2004, 11:54 AM   #6
jsmithrock
jsmithrock is an unknown quantity at this point
Use extensions and a swivel joint
jsmithrock is offline   Reply With Quote
Old 11-17-2004, 01:01 PM   #7
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
i got mine off with the usual extensions and a breaker bar
what i did was just get someone to hold the extension/socket onto the bolt and went from the back of the tranny with the breaker bar
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 11-17-2004, 01:04 PM   #8
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
I went in from the top. I think i had to manipulate the transmission with a standard autozone floorjack,
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
