Old 11-16-2015, 09:23 PM   #1
Cesar240
Cesar240 is an unknown quantity at this point
s13 S13 Overheating Diagnosis Help
So I Recently replaced the radiator, the upper and lower hoses, and a couple other Hoses and every time I would install the thermostat the car would over heat. So without the thermostat it wouldn't overheat so I ran it a few weeks without it and it was running perfectly fine and now it's overheating again. What else could it possibly be? I also heard a high pitch whistle noise coming out from under the intake manifold. Any suggestions on what to look for? Thanks!
Cesar240 is offline   Reply With Quote
Old 11-19-2015, 01:55 PM   #2
cotbu
cotbu's Avatar
Leak, blown gasket or just not sufficient cooling of the coolant, because no thermostat
Sent from my SM-N910T3 using Tapatalk
Old 11-25-2015, 04:16 PM   #3
grinevb
grinevb is an unknown quantity at this point
have the same problem and I took out the t-stat aswell except It never overheated on me without it? Mine only overheats with it in and still can't figure it out.
grinevb is offline   Reply With Quote
Old 11-25-2015, 10:08 PM   #4
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
You both still have air in the system.
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 11-26-2015, 10:26 PM   #5
Atill93
Atill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-known
yeah make sure you bleed all the air out of the cooling system. you can also do a pressure test and check your compression to see if you have a blown head gasket. you're experiencing the same symptoms i had when i finally discovered my head gasket was blown :/
Atill93 is offline   Reply With Quote
Old 12-09-2015, 03:14 AM   #6
sincity_sil80
sincity_sil80's Avatar
sincity_sil80 is an unknown quantity at this point
Mine is doing the same thing, but ive bled the system 4 times already. Have new POS radiator, new water pump, new hoses, and new thermostat, and its still running hot, after i bled the system today it ran cooler for longer but after a little while the temps start to rise again, any possibility air is somehow getting in or did i just not get it all out?
Btw, i have no coolant overflow tank, just a line routed under the passenger headlight temporarily.
20 till 3:00 =
sincity_sil80 is offline   Reply With Quote
Old 12-09-2015, 07:50 AM   #7
kruked
Trader Rating: (37)
Welp......
S13 coupe, KA-t
Old 12-09-2015, 07:52 AM   #8
boosted23
boosted23 is an unknown quantity at this point
Are yall using cheap waterpumps? Aftermarket cheap waterpumps have usually the wrong sized blades, they are usually shorter and fatter. Causes cooling issues
Sent from my SM-G900V using Tapatalk
boosted23 is offline   Reply With Quote
cooling system, ka24de, overheating
