Old 11-27-2015, 12:05 PM   #1
dil_s13
dil_s13 is an unknown quantity at this point
Exclamation S13 Digital Speedometer with HUD Reads 0
-1992 S13 KA24DE
-Manual transmission
-Digital cluster with HUD
I have searched through many forums, but cannot find my issue.
My speedometer does not work.
The digital screen in the cluster and the one for the HUD both light up and read 0. Any issues that I've read about that others have with the HUD cluster are concerning the screen not lighting up at all.
I have replaced the VSS with a new one.
Everything else in the cluster works, besides the odometer of course.
Any help is much appreciated.
dil_s13 is offline   Reply With Quote
Old 11-27-2015, 03:11 PM   #2
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Have you tried going faster?
Old 11-27-2015, 03:29 PM   #3
christianos13
christianos13 is an unknown quantity at this point
speed sensor?
christianos13 is offline   Reply With Quote
Old 11-27-2015, 03:32 PM   #4
dil_s13
133 MPH using GPS
Sent from my m8 using Tapatalk
Old 11-27-2015, 03:33 PM   #5
dil_s13
Originally Posted by christianos13 View Post
speed sensor?
I said I replaced the VSS with a new one.
Old 11-27-2015, 03:44 PM   #6
Gingersmurf
Gingersmurf is an unknown quantity at this point
Probably a bad ground somewhere.. good luck
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 11-27-2015, 05:14 PM   #7
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
Originally Posted by dil_s13 View Post
133 MPH using GPS
GPS isn't always correct.
Are you sure you weren't going 0mph?
Seriously though... I know something needs to be changed other than the cluster subharness. I had a digi cluster that read 0 in a vert I bought. I found the original cluster in the trunk with the sub harness... swapped back to the original one and it worked fine... So I'm sure the PO didn't change something, and I didn't care enough to find out what it was.
Kuma is offline   Reply With Quote
Old 11-27-2015, 11:55 PM   #8
gvelonoe
gvelonoe is an unknown quantity at this point
i like it very much,thank you
gvelonoe is offline   Reply With Quote
Old 11-28-2015, 10:07 AM   #9
dil_s13
Okay. So I found out that the wire from the VSS leads to a plug that is supposed to go to the cruise control module. Does anyone know how I can wire the two wires from the VSS directly to my speedometer?
digital, hud, s13, speedo, speedometer
