Wanted to Buy Post your needs and wants here. |
Wtb 93 differential mount
I need the 93 differential mounts. The 2 big ones closest to the driveshaft. Paypay/cash real
edit: Support front bushing??
IG- @TonyTunes ![]() |
![]() Join Date: Jun 2003
Trader Rating: (130)
93 diff doesn't have bushings in the front. its solid mounts. only s14 diff has bushings in the front.
this is an s13 diff ![]() this is an s14 diff ![]() |
Ok, whatever its called. I need the 2 things that fill the holes. Mine look like the s14 with big ass holes and a small bolt goes through it. Giving the diff way too much wiggle room
I'm like 90% sure this is what you're looking for.
may want to contact FRSport for confirmation http://www.frsport.com/DIF-10040-Dif...4_p_15043.html http://www.frsport.com/Stance-ST-20-...X_p_30341.html |
No, those goto the subframe that hold the diff up, correct? The photo you posted of the s14 diff where the 2 big holes are. I need those 2 things that fill those holes in. Its like a rubber bushing with a hollow bolt through it. You put it inside those holes then bolt it up to the frame.
http://www.frsport.com/SPL-SPL-SDB-S...2_p_15618.html
THIS kit has both the rear bushings (that bolt on to the rear cover) AND the front bushings that go to the ears you're talking about. I'm pretty sure the kits I posted earlier are JUST for the front two holes, NOT the rear cover. |
I run solid diff bushings (all 4) and solid subframe bushings. It does cause noise but I don't mind. If you want a quiet car, metal bushings are NOT for you.
