Old 03-08-2016, 04:32 PM   #1
TonyTunes
TonyTunes's Avatar
TonyTunes is a well-known jackass
Wtb 93 differential mount
I need the 93 differential mounts. The 2 big ones closest to the driveshaft. Paypay/cash real
edit: Support front bushing??
IG- @TonyTunes
TonyTunes is offline   Reply With Quote
Old 03-09-2016, 06:49 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
93 diff doesn't have bushings in the front. its solid mounts. only s14 diff has bushings in the front.
this is an s13 diff
this is an s14 diff
Old 03-09-2016, 02:28 PM   #3
TonyTunes
TonyTunes's Avatar
Ok, whatever its called. I need the 2 things that fill the holes. Mine look like the s14 with big ass holes and a small bolt goes through it. Giving the diff way too much wiggle room
IG- @TonyTunes
Old 03-09-2016, 02:42 PM   #4
brndck
brndck's Avatar
I'm like 90% sure this is what you're looking for.
may want to contact FRSport for confirmation
http://www.frsport.com/DIF-10040-Dif...4_p_15043.html
http://www.frsport.com/Stance-ST-20-...X_p_30341.html
Old 03-09-2016, 02:46 PM   #5
TonyTunes
TonyTunes's Avatar
No, those goto the subframe that hold the diff up, correct? The photo you posted of the s14 diff where the 2 big holes are. I need those 2 things that fill those holes in. Its like a rubber bushing with a hollow bolt through it. You put it inside those holes then bolt it up to the frame.
IG- @TonyTunes
Old 03-09-2016, 04:59 PM   #6
brndck
brndck's Avatar
http://www.frsport.com/SPL-SPL-SDB-S...2_p_15618.html
THIS kit has both the rear bushings (that bolt on to the rear cover)
AND
the front bushings that go to the ears you're talking about.
I'm pretty sure the kits I posted earlier are JUST for the front two holes, NOT the rear cover.
Old 03-10-2016, 06:45 PM   #7
TonyTunes
TonyTunes's Avatar
I think you're right on the money, don't know if I should go solid though as a daily. Anyone running those?
IG- @TonyTunes
Old 03-10-2016, 07:34 PM   #8
brndck
brndck's Avatar
I run solid diff bushings (all 4) and solid subframe bushings. It does cause noise but I don't mind. If you want a quiet car, metal bushings are NOT for you.
Old 03-11-2016, 12:44 AM   #9
TonyTunes
TonyTunes's Avatar
Both of my bushings are shot so anything would suffice from the horrible wheel hop I get right now haha. Thanks for the info
IG- @TonyTunes
