Old 11-30-2004, 01:59 PM   #1
AN89HATCH
AN89HATCH is a well-known jackass
How long will axles last on a welded diff?
I am going to be running a welded diff soon, and i heard that this will cause alot of stress on the axles. How long should they last around?? what do you guys do when you go to track,bring spare axles just incase??
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 11-30-2004, 02:19 PM   #2
the head
the head's Avatar
Location: in a dark room mastering the art of typing with one hand
the head is making a name for him/her selfthe head is making a name for him/her self
i think the better question is why are you doing a welded diff
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 11-30-2004, 02:31 PM   #3
AN89HATCH
Reason im doing a welded diff is because i do not want to spend 800 for a kazz and a vlsd will not cut it
slide your ride.com
Old 11-30-2004, 02:34 PM   #4
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
I think that really depends on the weld job.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 11-30-2004, 03:15 PM   #5
projectRDM
projectRDM's Avatar
So you must drive in a lot of straight lines. Cool.
The axles will hold up much longer than the welded diff.
FORMERLY R240NA
Old 11-30-2004, 03:16 PM   #6
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
depends on how hard you wll drive it and how much hp. upper 300's and ++ axles will break easily. stock HP and a few bolt ons will be fine i think.
s0ldats is offline   Reply With Quote
Old 11-30-2004, 05:11 PM   #7
AN89HATCH
actually i am using this for drift, i just need a cheap way to keep the rears locked
slide your ride.com
Old 11-30-2004, 05:27 PM   #8
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Has Luke had any complaints? Im pretty confident the diffs will hold up, and I havent heard of anybody breaking axles yet with a welded diff. Its hell on subframe bushings though.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 12-02-2004, 07:35 AM   #9
DTS
DTS is a well-known jackass
my buddy daily drives his s13 with a welded diff with no problems so far, he says it isnt as bad as everyone says at all.
DTS is offline   Reply With Quote
Old 12-02-2004, 08:40 AM   #10
orion::S14
orion::S14's Avatar
Exactly 17,453 miles, or 1.67 years...whichever comes first.
Hehe.
The stock 240SX axles are VERY strong...I bet they'll last pretty damn long.
- Brian
www.KA24DEvelopment.com
Old 12-02-2004, 01:19 PM   #11
AKADriver
AKADriver's Avatar
Not at all. As long as the spider gears are locked, no matter how sloppy the job, the stress on the half-shafts is just a simple fact of the tires wanting to turn different speeds and the halfshafts wanting to turn the same speed. This stresses the axles, and while it might not snap one, it'll ruin the CV joints much more quickly.
As R240NA said, it's hard as hell on the diff and that runs a good chance of blowing up first. But that won't matter because you already ruined it by welding it. But hey, if a car that handles like shit in any situation you're NOT drifting is worth that much to you... go ahead and fuck up your car.
Old 12-02-2004, 04:36 PM   #12
final act
final act is an unknown quantity at this point
Send a message via AIM to final act
exaclty what I was thinking!
final act is offline   Reply With Quote
Old 12-02-2004, 05:12 PM   #13
Buffalo Daughter
Buffalo Daughter's Avatar
Buffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enough
i've had one of luke's diffs, 2 actually and they are strong and react well. I havent heard any complaints from them and some people do prefer them more than other lsd's. hit luke up.
kick rocks.
Buffalo Daughter is offline   Reply With Quote
