No Cat... is this safe ?
i took my catylic converter off my 96 s14 and i was wondering if this safe for my engine. Some ppl are telling me that its fine for it and others are saying its bad for my engine b/c i have no back pressre so my valves will fry b/c they won't open and close when they should... will a knoledgable member of zilvia.net set the record straight!!!
![]() Join Date: Jun 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
you'll be cool, but you have a test pipe right?
![]() There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till. -Emerson |
![]() Join Date: May 2003
It won't "burn your valves"...that's an old BS rumor.
(That *could* happen if you ran NO header, so open valves to the atmosphere...but NOT in your situation) And you don't need backpressure...that's also a myth. So...with all that said: It's best to replace the cat with a test pipe or a high-flow...having just that big, empty area in your exhaust will slow you down. It needs to be smooth flow for high velocity...that is what's important. Not backpressure. And for what it's worth: SCC gained HP and TQ by adding a high-flow cat to their project 240SX... - Brian
www.KA24DEvelopment.com |
AFC #1
![]() Join Date: Oct 2003
This a 96 so the cat is in the downpipe not in the S13 location. That's just a holow shell.
![]() Join Date: Oct 2004
![]() You're going to screw up the rich/lean cycles programmed into your ecu, b/c there is no change in 02 between the 2 sensors now. You might want to get a cat simulator so that your ecu doesn't throw a catylist failure code for im240 emissions testing(if you are required to do it).
The only reason you would NEED backpressure is if you have a positive backpressure transducer in your EGR system, but i'm unsure if the 240 has it or not. Have fun spitting hydrocarbons everywhere. |
AFC #1
I have a OBX header which gets rid of the cat in S14's. My cat code get's throwen every 500+miles. Not a major pain. I still would like to know how he got rid of his cat.
#9 | ||||
![]() Quote:
hahaha you're crazy, your car will be stupid loud!
#13 | |
![]() Join Date: Nov 2004
PS: ive had some people telling me that when they were following me that when i would shift, there would be a blue flame shoot out from the exhaust about 3 inches out !!! ![]() |
#14 | |
![]() Join Date: Sep 2003
so you're running open header? right?
Hi |
#15 | |
AFC #1
This is a fake cat on the S14's ![]()
#16 |
whatever u do.. maybe just disconnect the battery for an hour (resets ECU) so it will just reprogram to whatever it reads and adjust blah blah?? I know I said that a million times to people who installed intakes at my previous job and it works, so maybe this would clear up some of that sensor bs...
Keep it Classy |
#17 | |
#18 | |
#20 |
![]() Join Date: Jan 2003
If you plan to stay with the ka with no cat but you want more power get the hotshot header. It gets rid of all cats (real and fake), flows smoothly and you will notice nice hp and torque gains.
#21 | |
![]() Join Date: Jul 2002
#22 |
![]() Join Date: Jan 2004
hp is not lost because of a lack of back pressure, and for some reason, the ka operates rather well in n/a form with no backpressure. in any situation back pressure does not make you lose power, it just ups your power band slightly, so technically you lose torque
#23 | ||
AFC #1
![]() Quote:
![]() The DP with the cat is on the left. A test pipe in place of the fake cat is in the center and the cat back is on the right(black).
#24 | |
#26 | |
no its not safe, you will kill all the plants and animals, all for a 2hp gain,
#27 |
Admin Asshole
![]() Join Date: Mar 2002
As long as you didn't remove the Muffler Bearings you should be ok.
#28 |
i have a hotshot header , which takes the "active cat" out , first off , and i have a enjukuracing testpipe , which replaced the dummy cat , and an hks hi power cat-back , its loud , and spits flames , but my check engine light has never come on , and it is so much quicker in the high end past 4k rpm,s ... hope that helps .
#30 | |
![]() Join Date: Dec 2002
I went with the HS header, Random Technologies high flow cat, and the Apex N1 dual. I don't like the High flow-to-exhaust portion casue of the size differences. Eventually i'm gonna change exhausts to a Greddy for noise. Oh yeah and get new gaskets and mounting bolts taht way it will bolt up easily and clean.
Don't mess with my monkey...he's loaded. |
