Old 07-25-2016, 02:24 PM   #1
KansaiDrifter
KansaiDrifter's Avatar
KansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud of
Arrow FS/FT 92 onevia VQ35DET S13 Pro2 car
Hello to all, I have decided to selll my 92' S13 coupe Pro-Am drift car. The car has dozens of wins from it's debut at Evergreen Grassroots and multiple championships. I've reached a point in my life that I'd like to work on some other projects and don't have the time to prep and run the drift car and I hate to see it sit in the garage when it should be out shredding tires! Does have plates, will get new tabs for new owner, clean WA title in hand.
*SOLD!* Thanks Zilvia!
I've gone through the math and I've put $36,000 into this car in parts alone. The labor was 90% by myself other then specialty things so you can imagine the overall cost to build this.
Link to overview video! I give a tour of the car and a little spin around the block, you have to crank the volume for the commentary, but it's there! [/COLOR]
https://youtu.be/SrimhN8pG4s
Chassis
• 1992 Nissan 240sx Coupe Clean WA title.
• Formula D spec roll cage by Position 1. Updated to 2016 spec by Chris Jeanneret
• Front and Rear bash bars by Chris Jeanneret
• Custom Full sheet metal inner front tubs built by myself very nicely done,
Suspension
• Powered by Max 2016 Ruca,Toe,Traction in the rear
• VooDoo13 Front billet tension rods
• Megan Racing Type RS Bound and rebound adjustable coilovers 7/5k springs
• 326 power S14 modified knuckles
• S14 braced lower control arms front w/new moog ball joints
• Megan Racing inner and outer tie rods
Brakes
• Wilwood 6 piston 13" rotor front brakes
• Wilwood 4 piston 13" rotor rear brakes
• Has the bracket already installed from Wilwood for running dual 4 piston calipers AND Brand New powered by Max hydro handle included
• CNC inline hydro handle for Ebrake, works great
• Stainless steel lines
• Z32 1 1/16 master cylinder
Body
• Origin Type 2 vented hood, 1 of 3 known in USA had a 1 year wait for it from Japan
• Origin racing line front bumper
• Origin stylish sides and rear
• Origin type 2 50mm rear widebody
• Origin 40mm vented front fenders
• Authentic Uras GT drag wing. Waited 6 months for shipping but worth it! 1 of 2 known in USA
• Cobra colorshift pearl plastidip. It's quick, easy and can be pealed off if you don't like it.
• Supermade Headlights custom made out of sheetmetal much better fit and finish
• PIAA Supermade driving lights with yellow and bright white lights
• Status LEDS custom taillights
Wheels
• 18x9.5 +15mm Chrome XXR 531 (4 total)
• 18x11 +15mm Chrome XXR 531 (4 total)
• Gold Powered by Max steel lug nuts
Interior
• OMP HTE-R Halo driver seat 2016 Formula D legal
• OMP WRC-R passenger seat
• Planted seat brackets Driver and Passenger
• Racequip 6 point seat belts
• Nardi 360mm deep dished steering wheel limited edition blue stitch
• NRG quick release
• Momo steering wheel hub
• Still has door panels, dash and carpet. Manual doors work great
• Fire extinguisher mount
Electronics
• Racepak IQ3 Haltech edition dash board
• Custom gauge cluster with fuel gauge, turn indicators and a/f ratio
• Innovative Wideband MTX-L A/F ratio controller/gauge in cluster
• Quickcar Toggle switch fused panel for Start/IGN/Lights/Heater/Windshield Wipers
• 2 position Turn signal switch on center console
• Master battery On/Off remove able key on center console
• Circuit Sports Fan controller
• Optima Red top battery
• Has functioning Wipers, Blinkers and Heater set to hot and defrost
Engine
• 2004 VQ35DE out of a 350z
• CP pistons .020" over bored, 9:1 compression dished for boost
• Manely factory length rods rated to 800hp
• Block dummy headed and torqued for all machine work. Work performed by Action Machine in Shoreline
• ARP L19 Headstuds
• ARP mainstuds
• Dynosty custom headgaskets
• Xterra cooling mod (rear factory thermostat for towing)
• Cosworth oil pan baffle kit
• ACL race bearings for rods and mains
• Heads and lower intake have had +80hours hand port and polish and gasket matching
• Ferrera +1mm stainless Big valves Intake and Exhaust
• Ferrera titanium retainers
• Ferrera double valve springs
• BC 272 cams
• New oem water pump, timing chain, tensioners
• VQHR oil pump new oem Nissan
• Kinetix upper intake manifold Stainless steel
• New Oem Nissan throttle body
• Custom one off 11gauge 304 stainless headers built by Gaelen Callahan vband 3-2-1 with cnc'd flanges in 304 ss
• Garrett GT3582R T3 flanged BB turbo center mounted
• Tial Super Q 50mm BOV and MVR Wastegate
• Griffin double row radiator
• Powered by Max swirl pot/overflow tank
• SPAL 16" +3000cfm puller fan
• Vibrant Performance Intercooler
• Custom Aluminum water and intercooler tubing.
• Chase bays Custom Mil Spec quick cannon plug engine harness
• Haltech Platinum Pro 350z stand alone ECU
• DBW 350z throttle pedal actually very snappy, better then cable
• MR2 electronic power steering pump
• Chase Bays Power steering reservoir and lines
• Custom Full stainless exhaust system with 2 rear sections, a ISR dual straight pipe for track and a Blitz NUR spec muffler for street use
• All rotating assembly balanced
• Cosworth Fuel Rails
• Injector Dynamics ID850cc 350z Injectors best money can buy I feel.
• Deatschwerks Fuel pump intank
• Tuned by Dom at 8psi for break in, ready for 20+psi now. On Shell 92 vpower gas 425rwhp currently, built for +700rwhp on next tune. Never got to tuning it for more, didn't need it.
Drivetrain
• 2006 350z CD009 transmission
• Spec twin disk full disk with flywheel combo capable of 1200 torque holding
• Custom driveline single piece
• OS Giken 2 way for a R32
• 94 Q45 Ring and pinion 3.54 gears (same as oem 350z)
• JDM 5 bolt axels and half shafts
• All OEM S14 5 lug conversion
• Ichiba Long studs front and rear wheel studs
*Most of my build pictures are on my facebook page here,
https://www.facebook.com/rh4motorspo...3157002&type=3
And here is a video of the interior and running
https://www.facebook.com/rh4motorspo...3157002&type=2
I can almost guarantee that I'm forgetting things as there has been years and tons of time poured into this beast with aspirations of running Pro2 Formula D with it but I've come to a point where I don't have the time anymore sadly and would much rather see her on the track then in my garage. Please contact me with questions and serious offers, test drives available only with serious buyers/ proof of funds. Thank you all very much for checking my car out and hope to hear from you soon. Thanks
-Ricky
Best way to contact me is email, I always forget to check on forums lol.
[email protected]
KansaiDrifter is offline   Reply With Quote
Old 07-25-2016, 02:50 PM   #2
TheRealSy90
TheRealSy90's Avatar
Awesome build here. Definitely a solid car for competition it seems.
Such a good signature.
Old 07-25-2016, 03:25 PM   #3
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Facebook links don't work. Might want to try making those videos/albums public.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 07-26-2016, 08:18 AM   #4
tuzzio
tuzzio's Avatar
Goddamn those tails are awesome
Old 07-26-2016, 12:45 PM   #5
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
Same, facebook videos no work.
Sweet car though
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 07-27-2016, 01:57 PM   #6
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
I really really dig this
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 07-31-2016, 08:52 PM   #7
KansaiDrifter
Thanks guys, it's been a amazing car since I've ran it and looking forward to someone driving like it should be!
Fixed the facebook pics link, not sure on the vid link, I'll try to get another video put together soon.
Old 08-01-2016, 09:26 PM   #8
KansaiDrifter
Added a link to a running video, it's public hopefully it'll work. I'm currently working on finishing the rear seat firewall so will update with that also. Probably tomorrow.
Old 08-02-2016, 06:29 AM   #9
subiesean
subiesean's Avatar
Video link at the top works, photos still don't.
You may want to get rid of the link at the bottom for videos that doesn't work.
Ho.Mo.Co.
Old 08-07-2016, 09:34 PM   #10
KansaiDrifter
I'm going to try uploading the video to photobucket or youtube soon. I'll probably just take a new one lol.
Finished the rear seat firewall and took a couple more pics of the interior. Also price droppage! $20,000 obo trades considered!
Old 08-14-2016, 10:04 PM   #11
KansaiDrifter
updated with a youtube video review of the car! Check it out!
Old 09-06-2016, 06:42 PM   #12
KansaiDrifter
meow bump still looking for a good home!
Old 09-06-2016, 08:24 PM   #13
Kylepaschke
Kylepaschke is an unknown quantity at this point
free bump.
any insight on your mr2 pump?
buddies got a crazy tt vq35de and we're looking for advice on how to hook it up (haltech pnp)
Kylepaschke is offline   Reply With Quote
Old 09-08-2016, 01:01 AM   #14
ghost_silvia
ghost_silvia's Avatar
ghost_silvia is an unknown quantity at this point
Nice car! I have that drag wing as well. Would love to have those tail lights.
ghost_silvia is offline   Reply With Quote
Old 09-10-2016, 02:44 PM   #15
KansaiDrifter
thanks guys! yeah the wing is my favorite!
Ah advice on the mr2 pump? It's custom everything lol. I started with a Chase bays power steering line/reservoir kit and had to make longer lines essentially. I setup mine under the passenger front inner fender well behind the headlight area. I made custom brackets for it there. I actually mounted it on it's side also. It's just a starter motor with a power steering pump haha. I used a mid 90's 2nd gen pump btw.
Old 10-11-2016, 09:37 PM   #16
KansaiDrifter
So car is still for sale. I am willing to keep things off it and let it go cheaper. Just looking to move it, it's been sitting for months now and rarely gets driven. I do run it at least once a month and go around the block but too many other things going on. Need to sell. Thanks
Old 10-11-2016, 11:40 PM   #17
nomoremrriceguy
nomoremrriceguy is an unknown quantity at this point
what are you willing to take off? I'm fairly interested
nomoremrriceguy is offline   Reply With Quote
Old 10-12-2016, 03:54 PM   #18
KansaiDrifter
Ah whatever I can to make a fair deal for both parties/budget, within reasonish haha. Have been considering selling the engine swap as a full package also. Pm me if you're interested, thanks
Old 10-12-2016, 05:06 PM   #19
TheRealSy90
Man if I somehow came across the money your asking I'd gladly pick this up. It's too complete of a build to part it out
Old 10-22-2016, 01:56 AM   #20
KansaiDrifter
Alright so I'm doing one more price drop hopefully someone can afford the car as a whole. I would very much like to sell this thing. Thanks
$18,000 obo.
BTW i did the math, I've got $36,000 in parts is the car from the basic car to now.
Old 11-07-2016, 12:46 PM   #21
KansaiDrifter
Still looking to sell, don't want to part it but will take things off to lower price even more! Hit me up for a incredibly competitive car
Old 11-07-2016, 07:17 PM   #22
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
I've been around since 2004 and still haven't seen a cage as good as Justin's. Welds, sure. Cage, no. Great cage, great car. GLWS.
Originally Posted by punxva View Post
i gotta fever, and the only prescription is moar hood vents
SlideWell is offline   Reply With Quote
Old 11-07-2016, 07:39 PM   #23
68whiskey
68whiskey is an unknown quantity at this point
You spent 36K on that car but put it on XXR rims?
68whiskey is offline   Reply With Quote
Old 11-09-2016, 12:18 PM   #24
signals13
signals13's Avatar
signals13 is an unknown quantity at this point
^^^^seriously that's what you're worried about? It's a competition car not a show/hard park car.
signals13 is offline   Reply With Quote
Old 11-09-2016, 03:07 PM   #25
JetS500
JetS500's Avatar
JetS500 is an unknown quantity at this point
Somehow it was the first thing I saw and thought too actually.. but i agree. Not a comp. car or hard parked car anyways, who cares if XXR bump for an awesome freaking car
JetS500 is offline   Reply With Quote
Old 11-09-2016, 03:50 PM   #26
signals13
signals13's Avatar
Old 11-15-2016, 07:09 PM   #27
KansaiDrifter
I have gotten more crap over the xxr's then I could of imagined. Nevermind it's a freaking drift car and guys like Odi Bauchis Finish in the top3 in points for Formula Drift with the same kind of thing lol.
It's a drift car, wheels are consumables on a drift car. I guess it's offensive to put the money into legit brakes instead of "dope" wheels. Noted I guess?
Seriously though I'm really looking to get the car sold so yeah I'm getting a bit depressed over how low this price has gone. Hit me up. thanks
Old 12-04-2016, 02:26 AM   #28
KansaiDrifter
Been getting some very interesting offers, not quite right yet but close! Hit me up
Old 12-05-2016, 10:29 AM   #29
bluz370
bluz370 is an unknown quantity at this point
My offer still stands if you get desperate and want to figure out transport with me.
bluz370 is offline   Reply With Quote
Old 12-13-2016, 08:51 PM   #30
graceott
graceott is an unknown quantity at this point
I can't afford this but holy shit dude she's beautiful. bump
graceott is offline   Reply With Quote
