SR is running rich then dies HELP!!!
So I need some help guys, I swapped to a top mount turbo on my SR and a external tial 38mm wastegate and when I fired it up for the first time it ran really lean then came back to ~14.7 until I bleeped the throttle and then it died while coming down. Now when I fire it up it goes full rich until it finally dies and won't idle or anything, so far this is what I've checked.
Fuel pressure is good Wastegate and aem truboost are hooked up as per aem Timing is correct Oil feed and return is correct and not leaking. Maf is plugged in and grounded. I'm going to double check vacuum lines but I'm pretty sure they are good to go, can just changing the position of the turbo on these motors really need a retune to idle? I can't figure this out guys and any help is appreciated. Btw so far the car has Fmic, don't know the brand Tomei FPR CX racing turbo (6063) and manifold, I figured I would give them a shot Custom down pipe 550cc injectors as per the retard I bought the car from Walbro 255 pump Aem truboost ebcs Tial 38mm ewg |
Changing injector size means you need a tune. It's an ecu from the 90s not a super computer.
MRP Manufacturing |
#4 | |
![]() Join Date: Sep 2005
did you guys even read that fuckery? plus this
i bet there's codes too!
![]() Join Date: May 2011
so before the fuckery continues, a little more info is needed, the car ran, you parked it and swapped the turbo and now it runs like shit? or the car hasn't ran except for how it was tuned before you owned it or x amount of time ago and you swapped this stuff and still cant get it to run?
pull your fuel rail with everything hooked up and see if any injectors are leaking, a lot of people who swap injectors reuse the old shitty o rings or don't grease them putting the injectors in, the o ring rolls and you leak extra fuel into the cylinder |
The car ran properly and was tuned for all of the parts that were on it before I swapped the turbo and manifold. The tune that is on the car is from rs enthalpy. The only thing I did was the turbo,which is the same size, the manifold and the external wastegate
I would check everything you had to remove to swap the turbo, was anything welded when you installed the parts, for instance welded the dump pipe after swapping the manifold to make sure the fitment was good? you could have broken maf wiring when removing or reinstalling it, maybe damaged the cas housing or plug? I would start checking everything in that area
![]() Join Date: Feb 2012
Trader Rating: (37)
![]() Feedback Score: 37 reviews
Can I please have a picture of the driver side of your engine bay? I want to see how shit looks around your exhaust manifold. Just take an overhead picture.
S13 coupe, KA-t |
#15 | |
I will lay down money something got broke and wasn't noticed when you were swapping parts |
#16 |
