Old 12-14-2004, 05:14 AM   #1
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
5 bolt VLSD axle.
Mine's broken, what other ones can I use?
S14 stock?
S13 stock?
Which ones are 5 bolt, and which ones are the thicky thick kind?
And also, I need to use the z32 TT nuts/bolts right?
95zilvia is offline   Reply With Quote
Old 12-14-2004, 07:42 AM   #2
Bone
Bone is an unknown quantity at this point
Send a message via AIM to Bone
J30, and Z32 are 5 bolt. S14 and S13 are 6 bolt. The 5 bolt axles require J30 bolts or z32 bolts you can by them from Nissan but they are $90! Not sure what you meant by thicky thick kind?
Bone is offline   Reply With Quote
Old 12-14-2004, 08:58 AM   #3
projectRDM
projectRDM's Avatar
Early J30 are 5bolt. 95-up are 6bolt.
FORMERLY R240NA
Old 12-14-2004, 11:21 AM   #4
Bone
Uh the 95 I pulled mine from was 5 bolt. 96 up could be 6 as I have no experience with those years.
Old 12-14-2004, 12:12 PM   #5
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
FWIW you can also use R32/33 Axles. Dunno if R34 would work.
Z32 axles won't fit, theyre too long IIRC.
kazuo is offline   Reply With Quote
Old 12-14-2004, 01:59 PM   #6
Toahk
Toahk's Avatar
Toahk is an unknown quantity at this point
Send a message via AIM to Toahk
Give me and email, which side do you need?
[email protected]
formerly Norcal_Drifter
http://www.cardomain.com/id/toahk
Toahk is offline   Reply With Quote
Old 12-14-2004, 03:07 PM   #7
95zilvia
emailed ur ass
Old 12-15-2004, 09:01 AM   #8
95zilvia
but my 5 bolt axles came with an lsd that bolted right up into the s13? now im confused, and i still need that axle!
Old 12-15-2004, 10:19 PM   #9
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
you must have got one the N/A 300zx diffs, or the earlier J30 diff. I have a set of 5 bolt axle for sale. Email me with an offer if your interested.
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 12-15-2004, 10:22 PM   #10
nissandr1ft
My axles are from a N/A Z32, and they will work on an S14 but not an S13. The Z32 axles are a little longer than the S14, and the S14 are a little longer than the S13.
Old 12-16-2004, 09:03 AM   #11
95zilvia
Maybe I got a JDM s13 diff with 5 bolt axles? is that another possibility?
Old 12-16-2004, 10:17 AM   #12
Toahk
Toahk's Avatar
Yes, and I didn't get your email. Can you try sending again?
Old 12-16-2004, 11:01 AM   #13
Bone
See I am really Confused now because form my understanding the J30 was the same length as Z32?!? If that is the case I have had this VLSD in both my S13 and S14 and had no problems with axle length on either.
Old 12-16-2004, 01:36 PM   #14
AKADriver
AKADriver's Avatar
Your understanding was wrong, J30 axles are shorter than Z32... approximately the same length as S13 or S14.
95zilvia, you most likely have a JDM S13 diff, yes.
