Old 12-14-2004, 06:47 PM   #1
BSPerformance
BSPerformance is making his/her stupidity well-knownBSPerformance is making his/her stupidity well-knownBSPerformance is making his/her stupidity well-known
Send a message via AIM to BSPerformance
92 KA PVC valve help
i just got a 240 and i cant find it.. im not even sure if there is one on it and i wouldnt be surprised if the owner uninstalled it and didnt reinstall a new one they didnt take care of the car.. could anyone of take a pic and circle where its at please thanks alot
a silvia
BSPerformance is offline   Reply With Quote
Old 12-14-2004, 06:55 PM   #2
meme
meme is making a name for him/her selfmeme is making a name for him/her self
if standing on the passanger side, it is to the right of the oil filter. i think it is right above the oil sender.
meme is offline   Reply With Quote
Old 12-14-2004, 11:42 PM   #3
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
The easiest way to get to it, is to remove the air intake pipe and all associated hoses, the alternator, and possibly the rad shroud (unless you can aqueeze there). It sits right behind the alt, going into the block. You can try removing from underneath, but will have problems getting a good grip with torque.
zero.counter is offline   Reply With Quote
Old 12-15-2004, 06:10 AM   #4
pr240sx
pr240sx is an unknown quantity at this point
Remove the alternator and the front intake manifold bracket.
If you have big and bulky hands (like me) removing these helps a lot.
Attack it from the underside (you need to remove the splash guard too!)
Its a 17mm size, use a good set of long nose pliers to remove the clip, by any chance, no not put any sealant around the new PVC threads.
pr240sx is offline   Reply With Quote
Old 12-15-2004, 09:15 AM   #5
nacstate
nacstate is an unknown quantity at this point
Be careful with it though, the hose going to it may be old and hard, thats what happened to mine. I finally got the damn thing loose (which takes forever, there's not much clearence for turning in there) and the hose broke.
nacstate is offline   Reply With Quote
