replacing piston rings...
does it require any machining work or can i just replace them and assemble the engine back together? Searched, but didnt really find much
![]() thanks |
This guy...
![]() Join Date: Feb 2003
to the very best of my no-ledge machine work is nessecary to ensure a proper seal. If your doing this on any two-4-d we are taking at a minimum of a 6/7 year old car so I would recommend having block machined to spec for the pistons to be installed.
We going high performance or stock?
My project car... From dust you were born, And to the ashes you return ~ Kill Switch Engage Family Guy Quagmire: Hey, how old are you sweet thang? Connie: 16. Quagmire: 18? Alllll-right! Connie: Mommmm! Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy! |
stock, the idea was to just replace the rings....
how much machining would there be needed? Guess is the same as with a full rebuild right? |
![]() Join Date: Mar 2003
probably no extreme machining, but a honing would be recommended.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
![]() Join Date: Sep 2002
Honing. But I've taken apart cars with over 100k and they still have the original crosshatch.
My 240 vBgarage |
I highly recommend honing. You may be able to get away with just throwing new rings in but you are gonna kick yourself if they don't seal correctly because of too much gap and you have to do it again. Do it right the first time.
#9 | |
This guy...
Ok for starter do not replace the piston rings with any other kind besides cast iron. They are the only ring that will make a seal in a bore that has not been machined.
You should Hone the cylinder with a flex hone or a spring loaded one to break the glaze and give the cross hatch so that the oil has a channel to hold on to, this will provide proper lubrication. Lacquer thinner might remove the glaze as well. Double check that the rings fit the pistons correctly and that the ring lands are not worn. Also make sure they fit the cylinder correctly. Like said above ring gaps should all be offset 180degrees. Good luck... Chris
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
I was reading this mustang mag a few years ago and they were building an engine and used a honing tool that they attached to the end of a drill. Dont know how accurate it would be but you need something
Accurate? It was either a ball hone or a 3 stone hone. Either one will work.
My 240 vBgarage |
#14 |
thanks for the help guys. Thinking about it though, its probably cheaper timewise to find a used engine and swap that in instead of taking the engine apart and then most likely messing something up putting it back together. Probably will stick with that idea.
