Old 10-10-2016, 09:42 AM   #1
Joeytofu
Joeytofu is an unknown quantity at this point
Ca18det turn key swap 2k
Ca18det turn key full swap
Rebuilt motor about 1k miles
Head, block machined decked and crankshaft polished
Stock Pistons and rods
Cosmetic street pro full gasket kit
Metal cosmetic head gasket
Acl race bearing
Acl main bearings
Arp head studs
Oem piston rings
Oem water pump
Oem timing belt
Oem tensioner
Oem oil pump
Aluminum pulley kit
R8 coil pack conversion
Ignitor chip bypass
Wiring specialties harness
Spec stage 3 clutch kit
Oem flywheel resurfaced
Jdm intercooler and piping
Real Greddy bov
Sr20 t25 turbo with adjustable wastegate
Megan racing motor mounts
Aluminum rad with silicone hoses
Sr20 downpipe
I want to 2k firm I have a lot more into this swap and it can easily push over 300 or more with the right supporting mods
Buy it now and get ur s13 running
Joeytofu is offline   Reply With Quote
Old 10-10-2016, 10:01 AM   #2
RHD*bro
RHD*bro's Avatar
RHD*bro is on the path to ruinRHD*bro is on the path to ruinRHD*bro is on the path to ruin
Bump for a ca18det
RHD*bro is offline   Reply With Quote
Old 02-16-2017, 12:03 PM   #3
nschaeffer32
nschaeffer32 is an unknown quantity at this point
ca18
if you still have it, text 4844645423
nschaeffer32 is offline   Reply With Quote
ca18det, s13 180sx 240sx hb, swap, turbo
