Old 12-14-2004, 07:15 PM   #1
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
Fuel pressure formula ???
is there a formula i can use to calculate the amount of fuel i will be pushing if i get an adjustable fuel pressure regulator. i plan to get a fuel pressure regulator to push my 370s on my SR a little more.
is that a dumb idea?? i dont plan to get too much more out of them. like 400cc+ if possible. im dont think im ready 4 550ccs.
$450 for a set of injectors or $125 for a regulator. if that helps.
....oooorr should i jus go to the yard and source up some RX-7(550s) injectors??
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 12-15-2004, 04:12 PM   #2
Muzzy
Muzzy's Avatar
stop holdin out on me bitches
lemme have a dollar
Old 12-15-2004, 04:31 PM   #3
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
Ok, I will help
Check this.
If you had 370cc injector tested at 43 psi and now tested at 50 psi, it would go like this.
50
----- = 1.1627 * 50 is the new fuel pressre, 43 was the old fuel pressure
43
Now find the SQ root of 1.1627 = 1.0763
Now multiply the old flow rate by sq root
370cc X 1.0763 = 398CC is the new rate @ 50 psi
you're welcome
Kid Zelda is offline   Reply With Quote
Old 12-16-2004, 08:52 PM   #4
Muzzy
Muzzy's Avatar
tank ye very much sir
lemme have a dollar
Old 12-17-2004, 12:59 PM   #5
89s132b
89s132b is an unknown quantity at this point
Math sucks, just use this. You will have to divide your 370cc/min by 10.5 to convert to lbs/hr but that is it...
http://www.csgnetwork.com/fiflowcalc.html
89s132b is offline   Reply With Quote
Old 12-17-2004, 09:11 PM   #6
Muzzy
Muzzy's Avatar
lol kidzelda's way is easier...to me...no conversions or anything....stright foward.
this should go FAQ i think or reference or somethin. we need a formula FAQ..sound good??
lemme have a dollar
Old 12-18-2004, 02:04 AM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
So whats the most PSI you can push out of the 370?
Old 12-18-2004, 06:05 PM   #8
NismoSilvia270R
NismoSilvia270R's Avatar
NismoSilvia270R is an unknown quantity at this point
Send a message via AIM to NismoSilvia270R
i wonder this too. i dont know too much bout injectors. want to know little more.(searching as i type in another window)
and how does duty cycle affect, or is affected by, changing fuel pressure with a fpr?
NismoSilvia270R is offline   Reply With Quote
Old 12-18-2004, 09:15 PM   #9
Mikel
Mikel is an unknown quantity at this point
Duty cycle won't be affected, the ECU doesn't know you've bumped the pressure, you just get more fuel for a given duty cycle.
Kinda a moot point anyway, if you're bumping the fuel pressure to push the injectors a little further, they're probably running static anyway.
Mikel is offline   Reply With Quote
Old 12-18-2004, 11:23 PM   #10
NismoSilvia270R
i was thinkin that whole thing was sketchy..
Old 12-19-2004, 01:48 AM   #11
Muzzy
Muzzy's Avatar
come on come on!!! more info. im not the only one with questions about this idea.
my other question is...wont i run super rich at idle without an SAFC if u up the fuel pressure?????
lemme have a dollar
Old 12-19-2004, 09:56 AM   #12
89s132b
The SAFC cannot adjust fuel when your ECU is in closed loop (i.e. while idling)
Your O2 sensor feedback will maintain your a/f ratios regardless of your fuel pressure and SAFC setings. But still you don't want to pump it up too much
Rule of thumb is don't run more than 60 psi. It takes 4 times the fuel pressure to double fuel flow so it doesn't help as much as you would think anyways. Raising the pressure to extreme levels is very hard on the pump and can lead to leaks or failures in the plumbing and injectors themselves. Plus it changes your injector latency so they won't be firing at quite the right (optimum) time.
It is much better to buy the right sized injectors.
hope this helps
Old 12-19-2004, 10:16 AM   #13
Jeff240sx
I hate you too...
Jeff240sx's Avatar
The injectors aren't affected nor limited by an increase in fuel pressure. The pump and regulator are. Running a lot of pressure on a pump is a sure way to kill it. Also, around 60psi, I wonder if the 255L/hr walbro can keep up. It's flow rate drops alot after 60psi. So much so that a slight hiccup and it may cost you a motor.
And the AFC doesn't raise fuel pressure. It changes the MAF voltage to trick the ECU into thinking more air is flowing into the motor than there really is.
-Jeff
Whatup?
Old 12-19-2004, 02:06 PM   #14
89s132b
If your REALLY want to increase the fuel pressure anyway, I'd suggest the 255lph "high pressure" version. It will withstand the higher pressure better than the regular 255lph pump. The biggest strain will be on the wiring (see graph). The stock wiring sucks. It would be a really good idea to run a low gauge wire idrectly from your battery to the pump, then relay it with the stock wiring. I did this to my car and a lot of the high HP guys (not me - LOL) do it too.
Regular 255 pump
High Pressure 255 pump
Old 12-19-2004, 07:02 PM   #15
Muzzy
Muzzy's Avatar
i know it doesnt change the fuel pressure...but doesnt the safc control injectors also??? because it will be pushin more fuel then normal all the time even at idle so wouldnt it cause it to be rich at idle????
yea im runnin the walbro 255 but not the hi-pressure one.
i can skate on 50psi dont u think??
lemme have a dollar
Old 12-19-2004, 10:12 PM   #16
89s132b
No, you won't run rich. Your O2 sensor will sense your afr's and adjust your fuel accordingly.
Yes, but if you have the 255 and stock fuel rail you are running about 50 psi already. I'd go 60psi if I were you.
Old 12-20-2004, 07:31 AM   #17
orion::S14
orion::S14's Avatar
No...SAFC modifies the MAF signal to trick the ECU into spraying less fuel...SACF does not connect to or directly control injectors.
FYI...
- Brian
www.KA24DEvelopment.com
Old 12-20-2004, 08:25 AM   #18
Mikel
Two things:
The Walbro 255lph High Pressure will keep up with some pretty high fuel pressures. I was running 43psi static and 1:1 rising rate indexed to boost on my GN. This translates to about 65psi at full boost. I believe it's part number GSS340
If you get a good AFPR, you can adjust point of onset so that your idle fuel pressure is the same as stock, and fuel pressure doesn't begin to rise untill you see positive manifold pressure. A good example of this is Cartech's regulator.
Old 01-05-2005, 03:30 PM   #19
j6k
j6k is an unknown quantity at this point
Send a message via AIM to j6k Send a message via Yahoo to j6k
formula
here's a formula, i think it's from GRM or some engineering book i have...
New flow = Old flow x (New pressure/Old pressure)^1/2
j6k is offline   Reply With Quote
