Old 03-26-2017, 02:35 PM   #1
itsMikey
itsMikey is an unknown quantity at this point
hesitation/bogging/died and now no start
alright...so the 240 the other day, started hesitating and bogging out all over the place and was idling rough. then it just died.
but now. the ecu's red indicator light isn't lighting up and the car still thinks the key is in the on position (dash on/seat belts retract when door is closed) it just started doing this when i went to go check the codes.
i can smell fuel a little bit on the intake side after i try to start it also...
and of course no start...just cranks
i can hear the fuel pump prime and the alternator tested good.
i'm lost....
itsMikey is offline   Reply With Quote
Old 03-26-2017, 03:26 PM   #2
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
Disconect the fuel line be sure you are getting fuel
Autozone sells cheap inline spark testers, make sure you have spark, start there.
Alternator has nothing to do with the car starting or not
GO DUCKS!!!!!!!!!
Juantwo3 is offline   Reply With Quote
Old 03-26-2017, 06:47 PM   #3
itsMikey
checked the fuel line. it's getting to the rail.
i'll look and see about the inline tester
alternator wasn't plugged in causing the wierd gauges and seat belt thing. fixed that.
Old 03-27-2017, 02:35 PM   #4
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Check if the plug under the passenger kick panel on the ECU connector that goes to the cluster is still hooked up. That connector has the cold start wire and the car will not start without it
nisileighty is offline   Reply With Quote
