Old 07-19-2017, 06:42 PM   #1
gtrpryde
gtrpryde is an unknown quantity at this point
HTP Invertig 201 aluminum TIG welder
HTP Invertig 201 (4-200AMPS, 200A@35%, 135A@100% , weldsALUMINUM, weighs 68 lbs, 240V 30 amp breaker.)
Used less than 5 hours, like new condition!
$1899, cash only, no trades, no checks
http://www.usaweld.com/Invertig-201-Welders-s/27.htm
Comes with:
HTP brand:
-Air cooled torch with lightweight flex hose
-Ground wire/clamp
-Foot pedal
-Regulator
-Gas line from gas cylinder to welder
-Magnetic torch holder
EXTRAS:
-1/16” 2% ceriated tungsten -$15
-1/16” 1.5% lanthanated tungsten -$15
-1/8” 2% thoriated tungsten -$15
Welding wire with costs I paid:
70S6 3/32 2 lbs- $21.50
70S6 1/16 2 lbs- $21.50
4043 3/32 2 lbs- $21.95
4043 1/16 2 lbs- $21.95
308L 1/16 2 lbs-$28.00
1/8" E6010 Radnor® 6010 Carbon Steel Electrode 10# Box - $31.86
3/32" E7018 Radnor® 7018 Carbon Steel Electrode 5# Box - $18.27
3/32" E6010 Carbon Steel Electrode 5# Box - $15
SPECS:
INVERTIG 201
Specifications #70201-12.5
Input Voltage
230 volts +/- 20%
Input Amperage
30 amps
Output Amperage
4 to 200 amps
Maximum Thickness-
Steel
Aluminum
3/8"
1/4"
Duty Cycle
35% @ 200 amps
60% @ 160 amps
100% @ 135 amps
No Load Voltage
65 volts
Arc Voltage
10 to 18 volts
Torch Length & Type
17 series 12½' long
Foot Pedal Length
12.½' long
Slope Down
0.1 to 10 sec
Pre-Gas Flow
0.5 sec
Post Gas Flow
2 to 20 sec
Final Current
0 to 99 amps
DC Pulsing Frequency
0.4 to 300 Hz
AC Pulsing Frequency
0.4 to 2 Hz
Pulsing Duty Cycle
65% - 30%
Pulsing Base Current
10% - 90%
AC Frequency
20 to 200 Hz
Balance Control
10 to 90%
Weight
68 lbs.
Size
20" L x 9 ½" W x 21" H
Call or text (preferred) 8three2 Four7Two 9zero1eight
gtrpryde is offline   Reply With Quote
