Old 11-13-2017, 06:28 PM   #841
CrunkGoat
CrunkGoat's Avatar
CrunkGoat is an unknown quantity at this point
So here's a question that I haven't seen pop up yet. It's known that you need to machine the stock rwd crank pulley and get a spacer for the oil pump drive when running the sr20ve cover on a rwd block. But can you use a combination of stock fwd parts and not have to bother with the machining? Have a full p11 sr20ve sitting in the garage is why I ask.
For instance can you run the fwd pulley and be fine? Run the fwd crank/pulley with rwd rods/pistons?
CrunkGoat is offline   Reply With Quote
Old 11-13-2017, 07:23 PM   #842
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Water pump and alternator wouldn't line up or rotate at the correct speed.
[email protected]
hanzbrady is offline   Reply With Quote
Old 11-13-2017, 07:59 PM   #843
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
None of it fits correctly
timing marks, pulleys, nothing
Been done.........with horrendous results
RalliartRsX is offline   Reply With Quote
Old 11-14-2017, 04:16 AM   #844
CrunkGoat
CrunkGoat's Avatar
Well there goes that idea Lol, thanks for clearing it up
Old 11-15-2017, 03:53 PM   #845
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
on my built im running the p11 oil pump spacer and machined the crank pulley ... i felt it was less of a trouble for me to run it like that vs the det oil pump drive with mazworx spacer ... i dont know of any fwd acc. that would fit bolt on
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 11-15-2017, 04:04 PM   #846
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
I did the same. brand new p11 oil pump drive collar is cheap to come by, machined a few mm off the back of the pulley and it all lines up nicely
Old 12-22-2017, 12:36 PM   #847
rbs14kouki
rbs14kouki's Avatar
With the new g25-550 and g25-660 im thinking of going that route for my turbo ... is there anybody running one yet since they came out at Sema 2017 ??
AV FABRICATION
Old 01-17-2018, 10:28 AM   #848
peglio
peglio's Avatar
peglio is an unknown quantity at this point
The Sr20/Sr22vet thread
Just read the whole thread start to finish , lots of great info here !
Bit of a random question , saw the efr7670 mentioned a few times is anyone actually running one on a vet set up at all?
I’m In the process of building a 22vet for my widebody s15 and I actually have a full race twin scroll twin gate efr7670 to go on it . Doesn’t seem to be many dyno charts or street drive info about for these so was wondering if anyone has experience of this turbo on these engines at all? Thanks in advance
Sent from Big Bear Kustoms Ltd
peglio is offline   Reply With Quote
Old 01-18-2018, 06:37 AM   #849
insa
insa is an unknown quantity at this point
Works great. A drift car in Austia runs one in an AE86.
Our 647.9 PS translated to about 640 of your horsepowers.
SR23VET, 91x90mm, 9,8:1 compression, E85, 7670 T4 TS internally gated
insa is offline   Reply With Quote
Old 01-18-2018, 06:47 AM   #850
RalliartRsX
Trader Rating: (32)
^^ 368 ft lb by 3600-3700 RPM! WOw!
Old 01-18-2018, 07:32 AM   #851
peglio
peglio's Avatar
That’s awesome ! Thanks for taking the time to respond , looks like a lovely delivery of power too !
Mine is the twin external gate AR 1.05 so won’t pick up quite as quick I should imagine as the internal twin scroll is 0.92 I believe, should still be pretty good judging by that graph though [emoji16][emoji16]
Old 01-20-2018, 08:31 AM   #852
insa
Yes and holds it pretty well up top, too
Cheers. Yes, the integrated wg t4 is 0.92, but I guess yours will not be that much different (just everything shifted a bit to the right).
In about 2-3 month my new 2.25l VE will be dyno'd with a 7163 .80. It's about the same spec as the other engine. Will let you know how that went...
Old 01-20-2018, 09:31 AM   #853
peglio
peglio's Avatar
Nice ‘ look forward to seeing how that stacks up , they look like real nice turbos , very responsive !
Yeah I guess it shouldn’t be that different really maybe a little less down the bottom and a little more up top. Shall find out soon enough [emoji16]
Old 01-30-2018, 05:08 AM   #854
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
anyone using Audi R8 coilpacks with standalone EMS?
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 01-31-2018, 07:31 AM   #855
peglio
peglio's Avatar
Meant to ask , do they run 3” or 3.5” exhaust on that set up buddy ?
Old 02-03-2018, 03:06 PM   #856
gt3071r240
gt3071r240 is an unknown quantity at this point
has anyone ran a P11 intake cam and a 16ve exhaust cam?
Specs below...
Sr20VE
Intake cam
Low lobe: 8.4mm lift @ 220 duration
Low lobe center angle: 110deg
High lobe:10.7mm lift @ 264 duration
High lobe center angle: 104deg
Sr16VE
Exhaust cam
Exhaust cam
Low Exhaust Duration: 244
Low Exhaust Lift: 7.95
Low Exhaust Center Angle:122
High Exhaust Duration: 280
High Exhaust Lift: 11.1
High Exhaust Center Angle:110
Curious on results as I cannot seem to find a set of P12s...
gt3071r240 is offline   Reply With Quote
Old 02-04-2018, 12:19 AM   #857
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
VVL CAMS
OE SR20VE cams
Low lobe INTAKE - .331" (8.4) LIFT /220º DUR - Low lobe EXHAUST -.260" (6.6) LIFT / 244º DUR - OVERLAP - 0º
High lobe INTAKE - .421" (10.7) LIFT /264º DUR - High lobe EXHAUST -.407" (10.34) LIFT / 268º DUR - OVERLAP - 48º
OE SR16VE:
Low lobe INTAKE - .279" (7.1) LIFT / 200º DUR - Low lobe EXHAUST - .313" (7.95) LIFT / 244º DUR - OVERLAP - 0º
High lobe INTAKE - .437" (11.1) LIFT / 280º DUR - High lobe EXHAUST - .437" (11.1) LIFT / 280º DUR - OVERLAP - 70º
OE SR16VE N1:
Low lobe INTAKE - .331" (8.4) LIFT / 220º DUR - Low lobe EXHAUST -.313" (7.95) LIFT / 244º DUR - OVERLAP - 0º - RED
High lobe INTAKE - .472" (12.0) LIFT / 288º DUR - High lobe EXHAUST -.469" (11.9) LIFT / 288º DUR - OVERLAP - 74º - GREEN
OE SR20VE 20V:
Low lobe INTAKE - .398" (10.11) LIFT /228º DUR - Low lobe EXHAUST - .327" (8.3) LIFT / 244º DUR - OVERLAP - ---º
High lobe INTAKE - .472" (12.0) LIFT /278º DUR - High lobe EXHAUST - .439" (11.15) LIFT / 280º DUR - OVERLAP - 57º
OE SR20VET:
Low lobe INTAKE - .315" (8.0) LIFT / 212º DUR - Low lobe EXHAUST -.445" (11.3) LIFT / 244º DUR - OVERLAP - 0º - PINK
High lobe INTAKE - .433" (11.0) LIFT / 248º DUR - High lobe EXHAUST (LOW Lobe is used) -.445" (11.3) LIFT / 244º DUR - OVERLAP - 13º - LIGHT GREEN
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 02-05-2018, 02:05 AM   #858
insa
Meant to ask , do they run 3” or 3.5” exhaust on that set up buddy ? Sent from my iPhone using Tapatalk
Sorry, I don't know. My personal opinion: Running anything smaller than 3.5" with a turbo this size, will result in a loss of "spool".
Old 02-06-2018, 05:37 AM   #859
s13silvia123
P11 CAM CARD
Old 02-06-2018, 05:47 AM   #860
s13silvia123
SR20VE OE VALVE LASH ADJUSTMENTS
P11:
0.25mm intake
0.32mm exhaust
P12:
0.20mm intake
0.34mm exhaust
N1:
0.17mm intake
0.37mm exhaust
Directly from the FSM apparently. All of them are +-0.05mm
P12 SR20VE VALVE LASH ADJUSTMENTS
You can run
.004"-.006" on the intake
.006"-.008" on the exhaust
and make sure you are within .001" on the paired valves.
credit: STR8E180 and Mazwox
Old 02-07-2018, 02:04 AM   #861
insa
Originally Posted by s13silvia123 View Post
P12 CAM CARD
This is referring to the normal SR20VE, not the P12 SR20VE 20V Variant, I think.
Old 02-07-2018, 05:30 AM   #862
s13silvia123
Right, it is referring to the normal P12 cams
Old 02-07-2018, 05:33 AM   #863
RalliartRsX
Trader Rating: (32)
That's not the P12 cam card. That's a P11
Old 02-07-2018, 06:25 AM   #864
s13silvia123
info changed...........
Old 02-07-2018, 05:51 PM   #865
CrunkGoat
CrunkGoat's Avatar
Has anyone seen EFI Hardware's VE ITB kit yet?
https://www.efihardware.com/products...Pro-Series-Kit
Look pretty slick but that price tag kind of turns me off. Still thinking on them very hard since my 11:1 NA build has their name written all over it but shipped to my door (canada) after duty/taxes a Mazworx intake and 90mm TB is $1100cdn cheaper... that's a lot of money for not much if any hp gain...
Old 02-07-2018, 06:35 PM   #866
Yellow4g63
Why not go 12.5? and make some ITB's out of the M3 CLS ITB's?
91 Nx2000 VVL yo
Old 02-07-2018, 08:42 PM   #867
CrunkGoat
CrunkGoat's Avatar
I'll be running a little more then 11:1 since that's what the pistons claim for a De head but don't have the best gas around here to go much higher.
And are the adapters everyone used still available for the m3 itbs? Could always get them welded to a flange I suppose if not
Old 02-07-2018, 09:38 PM   #868
Yellow4g63
Don't think they are available anymore. Watch out for those de pistons and cams bigger than the factory p11 be. You might bend valves.
91 Nx2000 VVL yo
Old 02-08-2018, 02:44 AM   #869
CrunkGoat
CrunkGoat's Avatar
Cool thanks. And yeah I'm fairly sure I'm going to have to get the pistons flycut for the valves, was looking at kelfords haha
Old 02-10-2018, 01:32 PM   #870
gt3071r240
ok so considering changing turbo for the build...I currently have a Gt35r .82 AR, and considering going to a GTX3071r gen 2 in a .63 or .82 AR
Motor specs currently are:
CP 9:1 DET 87mm piston on stock sleeves
calculated compression is 9.285:1 with decking
1.8mm apexi headgasket
Eagle Rods
Mazworx head studs
P11 VVL head with Supertech 93lbs springs
P11 Cams
Mazworx Intake/Kit
ID1300 ATL FC with Bosch 088
all other supporting mods are there...
tunning will be on pump and C16 for now until I put in E85 compliant fuel lines
Not really looking to make more than 550Whp as it think the bottom end will become an issue.
Thoughts..
