Old 01-24-2018, 11:12 PM   #1
Pixel6
Pixel6's Avatar
Pixel6 is an unknown quantity at this point
91 JDM Silvia axles - need source.
Hiys guys, I’m finishing up my rear subframe rebuild, (ditching the super HICAS, so using a USDM subframe) and decided to go with my stock LSD rather than the open diff we welded. The welded diff is 3x2 bolt pattern, and my LSD is 5x1 bolt pattern. Pic attached is the subframe build, with the axles for the welded diff. So, looking for the other axles.
I’ve been looking for some time, but can’t seem to source a set of remanufactured axles with the 5x1 bolt pattern. Can anyone point me to a source that has these?
Again, I need the 5 bolt pattern rear differential cv axles (L+R) on a 91 Silvia with a LSD
Thanks.
File Type: jpeg B3CFBD8A-1BC2-4925-889D-F4377AB6B245.jpeg (498.6 KB, 16 views)
Pixel6 is offline   Reply With Quote
Old 01-25-2018, 07:48 AM   #2
jedi03
Doesn't the q45 have the 5 bolt? its been a while since I looked...I personally swapped the output shafts on the diff for the USDM s13 ones to run any available axle I could...
Old 01-25-2018, 08:00 AM   #3
tuzzio
tuzzio's Avatar
There is a handful on ebay. Swap output shafts, or the diff to usdm ones.
Old 01-25-2018, 10:26 AM   #4
TheRealSy90
TheRealSy90's Avatar
The open (now welded) diff output shaft do not work correctly in the vlsd housing that he has in his differential.
You could however swap the inner cv's from your 5 bolt axles onto the rebuilt 6 bolt axles, the shafts are the same.
Such a good signature.
