Old 03-12-2018, 04:28 PM   #1
Sirdriftsalot
Sirdriftsalot's Avatar
Sirdriftsalot is an unknown quantity at this point
Is there a solution for this? Steering ujoint won’t reach the rack
After relocating my steering rack forwards, I am no longer able to connect the steering shaft ujoint with the rack bc it’s to short to reach. Has anyone been through this before and knows a solution?
Sirdriftsalot is offline   Reply With Quote
Old 03-12-2018, 05:24 PM   #2
TheRealSy90
TheRealSy90's Avatar
The steering shaft that the u joint secures to should actually telescope a bit too I think.
Also, did you loosen the other side of the u joint and slide it down as far as possible?
Such a good signature.
Old 03-12-2018, 06:21 PM   #3
Sirdriftsalot
It does and yes I slid it down however it comes off the shaft when the ujoint fits correctly on the rack.
Old 03-12-2018, 08:24 PM   #4
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
You mean other than extending the steering shaft by cutting and welding?
Tuners are big bullies
feito is offline   Reply With Quote
Old 03-12-2018, 09:26 PM   #5
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
No way man, grab the shaft and jank/wiggle that bitch it will reach it telescopes a good bit like inchs ... a few inches
Bnr32gtr is offline   Reply With Quote
Old 03-12-2018, 09:56 PM   #6
Sirdriftsalot
I was hoping to not go that route but I might have to if my other plan fails. I’m gonna try to stack 2 bushings on top each other to see if it’ll raise the rack a bit to reach
Old 03-12-2018, 09:58 PM   #7
Sirdriftsalot
I tried, I’ll try again tomorrow with more force
Old 03-13-2018, 07:48 AM   #8
TheRealSy90
Yeah there's no way you relocated the rack that far forward, it should extend a decent amount.
Old 03-13-2018, 08:25 AM   #9
jedi03
i did this with my fc...just cut at extension and weld!
Old 03-13-2018, 08:39 AM   #10
PatPs13
PatPs13's Avatar
PatPs13 will become famous soon enoughPatPs13 will become famous soon enoughPatPs13 will become famous soon enoughPatPs13 will become famous soon enoughPatPs13 will become famous soon enough
No need for cutting and welding..
with the rack unbolted from the subframe, throw the column into the yoke, tighten it, then bolt the rack to the subframe. As you tighten down the brackets the steering column will extend.
PatPs13 is offline   Reply With Quote
Old 03-13-2018, 09:00 AM   #11
Sirdriftsalot
I’m gonna give this a go!
Old 03-13-2018, 11:30 AM   #12
TheRealSy90
Ah, I never thought of that lol. Hopefully the rack mount screws are long enough
