Old 03-11-2018, 09:39 PM   #1
doridoridori
doridoridori is an unknown quantity at this point
SR20 STI 550cc injector pigtails question
had a quick question, so i went with the yellow 550 sti injectors (04-06), a friend had told me to order some denso connectors and put them in place of my stock injector clips. Problem is the ones i got do not fit properly. Wanted to know does anyone have a direct link where i can buy pigtails that will fit with no issue?
doridoridori is offline   Reply With Quote
Old 03-11-2018, 10:24 PM   #2
oLemurs
oLemurs's Avatar
oLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura about
did you get the ebay special denso connectors? it looks like these should just plug right in you just do the pigtail wiring. https://www.wiringspecialties.com/de...tor-connector/
oLemurs is offline   Reply With Quote
Old 03-11-2018, 10:37 PM   #3
doridoridori
yea the ones i got were from ebay, they had sti as one of the labels but they didn't work, tried them before?
Old 03-11-2018, 10:46 PM   #4
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
I used 350Z pig tails on my STi yellows. wiring specialties should have them.
Review Thread
bardabe is offline   Reply With Quote
Old 03-11-2018, 10:50 PM   #5
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
I purchased these for my 550cc yellows: https://motorwestperformance.com/product/c120-4pack-l1/
Work like a charm. No soldering and easy to switch back to stock (California ughhhh)
Ilya is offline   Reply With Quote
Old 03-11-2018, 11:02 PM   #6
doridoridori
would do that but cut the connectors already, looks like WS it is, appreciate the help from everyone
Old 03-12-2018, 08:19 AM   #7
jedi03
any Subaru should have the same clip...buddy clipped mine for me from an NA outback at the junkyard
Old 03-14-2018, 08:11 AM   #8
thom
thom is an unknown quantity at this point
Why use pigtails ?
I have those on my sr20 and the only thing i did was a little trimming on the side of the injector and move the pins inside a little on an angle. And they fitted perfect .
thom is offline   Reply With Quote
Old 03-14-2018, 07:19 PM   #9
doridoridori
Originally Posted by thom View Post
Why use pigtails ?
why use pigtails? not sure i understand what you mean by that, from my understanding the connector to the injector with wires at the end would be considered an injector pigtail, no?
Old 03-15-2018, 12:22 AM   #10
thom
Sorry i meant why use different Because i used the original, just unplugged the stock injectors and with that small modification i mentioned i put them on.
Old 03-15-2018, 06:28 AM   #11
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Another option would be the nismo 555cc injectors. Reasonably priced IMO
https://www.ebay.com/itm/4x-OEM-NISM...VY-Bdn&vxp=mtr
No dicking around with other pigtails or soldering into injector harness...
Just plug, tune, and dori
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 03-15-2018, 07:36 AM   #12
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
or just go to EVERYJUNKYARDINAMERICA
clip pigtails off ANYSUBARUEVER
leave.
Old 03-15-2018, 07:58 AM   #13
jedi03
that works too...but for those who don't like trimming...its 2 wires and I have yet to see anyone mess up the wire order to cut and solder or butt connect the wires
Old 03-15-2018, 10:34 AM   #14
brndck
brndck's Avatar
literally you can't mess up the wire order. you can reverse it and they work fine. an injector is just a switch. on. off. doesn't matter which end gets power and which end gets ground.
Old 03-15-2018, 07:34 PM   #15
doridoridori
originally wanted to do that but don't like the JECS, wanted oem, i've heard ppl have issues with JECS
Old 03-15-2018, 07:36 PM   #16
doridoridori
oh ok no worries, well trimming the injectors i'd imagine they don't clip in place and can possibly pop off, definitely want them secure. either way clips came in yesturday going to get them on this weekend finally and should be able to get the car started
Old 03-16-2018, 01:16 AM   #17
derass
What? JECS is an OEM. They make the Nissan / Nismo / Tomei / HKS sidefeed injectors. Your STI injectors are JECS too.
Old 03-16-2018, 01:42 AM   #18
doridoridori
sorry said that wrong, i mean the cheaper aftermarket jecs injectors have been known to be 50/50. also heard (not sure if true or not haven't personally dealt with this) but some injectors are labeled via ebay as jecs oem and aren't, i only really trust oem injectors i know pulled from a vehicle. seems like if the price is cheap enough on ebay they could be oem looking replica injectors. Either way got the injectors i need
Old 03-16-2018, 01:43 AM   #19
doridoridori
leave.
would have did that but with my work schedule i'll never make it to a junkyard before they close
Old 03-16-2018, 09:17 AM   #20
Ilya
Ilya's Avatar
What injector latency do you use with the STIs? I have a hard time believing that the latency is 1050uS for 550cc.
Also, you cannot beat the price of Yellows, for 120$ you have superior quality injectors with brand new adapter pigtails.
Old 03-16-2018, 02:03 PM   #21
derass
Gotcha. Calling them "aftermarket jecs" isn't quite accurate though. Those eBay ones for $150 clearly are not JECS, but rather some other aftermarket brand. It's damn near impossible that they're OEM quality for that price.
And then there are re-drilled injectors like Five-0 and Deatschwerks. They either start with a stock JECS or other injectors and drill out the tips for more flow. The quality and resulting spray pattern are often garbage.
http://www.motoiq.com/MagazineArticl...Injectors.aspx
Old 03-18-2018, 12:26 PM   #22
doridoridori
thanks for clearing that up, my term was wrong i think i meant to say redrilled, someone told me to stay away from those. And you are right for how cheap that price was sounds too good to be true and it usually is. I just had a fresh engine rebuil, spent a pretty penny don't want any failure due to re-drilled injectors. I've heard bad stories. Either way got my injector clips in put them on yesturday and they fit just fine.
