Old 05-14-2018, 10:50 PM   #1
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
S14 blender door actuator question.
Silly question, I've been bleeding my cooling system all this time with my blender door actuator on "cold" slider was on hot but the rod was bent and wasn't able to change to "hot"
Now, should I go ahead and bleed my system again or does it make a difference?
97 240sx
Ig: @ozckouki
IG: @ozc2jz
oscarsx is offline   Reply With Quote
Old 05-15-2018, 07:42 AM   #2
jedi03
it can make a difference as an air bubble can get trapped there...not always but usually...I would recommend bleed again
Old 05-15-2018, 02:09 PM   #3
oscarsx
oscarsx's Avatar
That was my concern, I'll give it a go. Thanks dude.
Ig: @ozckouki
IG: @ozc2jz
Old 05-15-2018, 05:35 PM   #4
dbeiler
dbeiler's Avatar
The '97 240 does not have a heater shutoff valve. Coolant will always have 100% flow through the heater core regardless of the temperature position you set. The temperature switch simply directs air through or around the heater core.
Old 05-17-2018, 06:15 PM   #5
Calver
Calver is an unknown quantity at this point
That explains it. Good info
Calver is offline   Reply With Quote
Old 05-17-2018, 06:31 PM   #6
jedi03
Cool I always do heater open just in case but thank you for the info for being vehicle specific!
