Old 06-14-2018, 03:53 PM   #1
Eviltaco805
Eviltaco805 is an unknown quantity at this point
Does anyone know where this ground wire goes to? [Solved]
I noticed this wire has been hanging and my 89 240sx is in limp mode and i unplug sensors and the car sounds better and now when i switch my ignition on the off position the car is still running even with the key out and with the battery unplugged the only way i get it to shut off is if I take out the efi relay. I have no clue on what's going on. https://imgur.com/a/HTI6Afj
Update: i replaced the chassis and engine harness from a manual and ecu now the car runs and revs pass 2,500 rpms now
Eviltaco805 is offline   Reply With Quote
Old 06-14-2018, 06:59 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
whoa dude that's way too many things.
what sensors did you unplug? what is "limp mode"?
was the car running fine before? did you change anything or modify anything? or was the car running fine one day, you changed nothing, and then the problem started?
we need a lot more information than you're providing.
my best guess is you damaged something in the ignition switch, and now its not triggering the EGI relay to go open.
Old 06-14-2018, 07:36 PM   #3
Eviltaco805
The car ran fine before i changed my water pump and then ran into the problem of limp mode where the car won't go pass 2,500 rpm and i even tried my friends MAF to see if that was the cause of limp mode but it didn't work and I unplugged all of the engine sensors and it was still running.
Old 06-14-2018, 09:11 PM   #4
brndck
brndck's Avatar
Yeah if the car won't go over 2500 rpm it's almost always a maf or maf wiring issue. Unplugging other sensors won't cause the car to stall unless you unplug the distributor or enough injectors to starve fuel.
Step 1: verify that your maf wiring is good. This might be as simple as a shitty or corroded connection. You can get electrical terminal cleaner at autozone, and a wire brush or toothbrush.
Old 06-14-2018, 09:32 PM   #5
Eviltaco805
Okay I'll try it tomorrow and keep you updated thank you
Old 06-17-2018, 01:47 AM   #6
Eviltaco805
okay so i recently looked at my chassis harness and noticed a lot of stuff has been bypassed and hacked up so im just going to replace the harness and noticed my dash harness also has been hacked up too so ill have to replace those and hope that fixes the problem. also i had a question about will a dual cam chassis harness and dash harness work on my 89 s13?
Old 06-18-2018, 01:17 PM   #7
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
Or you can just check your maf wiring and get it running now and change the harness later. Don’t make it more difficult than it is. The tell tale symptom is that you can’t rev past 2500rpm - it’s the maf or wiring to it
5.3 V8 Swap w/ Nitrous
unicoder is offline   Reply With Quote
Old 08-06-2018, 04:11 PM   #8
Eviltaco805
Thank you for the help i fixed the problem
Old 08-06-2018, 04:12 PM   #9
Eviltaco805
Thank you for you help i fixed the problem
