FT 2003 E46 M3 6 speed
2003 carbon black m3 6 speed coupe.
Clean NV title Has 148xxx miles and will go up due to it being my daily. All windows and sunroof work, ac heat power steering traction control , sport mode Car has -status gruppe coilovers -ECS front and rear strut tower reinforcement plates -BHS under drive pulley kit (replaces plastic power steering, water pump pullies and alternator pulley) -Rear subframe HAS been reinforced -Clean black interior with aluminum trim. -DIY Amber corner lights front and rear -LED halo lights -Rear Led tails Varrstoen wheels 18x9.5 F 255/35/18 18x10.5 R 275/35/18 -ECS poly transmission mounts -Stainless steel front and rear brake lines. Cons: -Paint is ok. It has its areas that any 20+ car would. But it's pretty clean. -No radio. It came with the OEM double din nav Harmon kardon setup but it gave out so I pulled it out but never got around to putting a new unit. (S54 sounds better then most music now a days anyway) -Missing one fog light trim, lost it after a commute to work (took the fogs out in the time being) -no trunk interior lining - front bumper needs some attention in areas With that being said, the car drives and pulls as it should, sounds good no lifter ticks or grinds into any gear. Clutch grabs like it should. asking 12,000 obo. can reduce price if you bring your own 5x120 wheels Last edited by evotea; 11-25-2018 at 06:16 PM.. |
