Old 01-14-2005, 08:47 PM   #1
neilio85
neilio85 is an unknown quantity at this point
R33 GTR wheel fitting questions
Hey everyone, I recently purchased a set of R33 GTR wheels for my S14. I just have some questions about how to get the best look and fitment.
1) What size of tires should I run on them?
2) What size of spacer should I run to make them as flush as possible? Also, should I run a different size on the front than on the back?
3) Once I order SPL's coilovers will I be able to go quite low without having to pull or roll the fenders and what kind of camber will I have to run?
Thanks in advance.
Neil
neilio85 is offline   Reply With Quote
Old 01-14-2005, 10:13 PM   #2
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
1. 215/40/17 and 225/45/17
2. 25mm of spacers in front and 30mm of spacers in the rear
3. no. you need to roll and MAYBE pull a little bit. fronts should run -3 degree and rear should be -3 as well.
my settings will PROBABLY work. try it and find out.
http://bhworld.wordpress.com/
Old 01-14-2005, 11:26 PM   #3
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
yup thats just about what i run.
215/45 and 25mm spacers all around and about - 3 degrees of camber give or take all aroud as well. i only rolled my fenders too, no pulling.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 01-15-2005, 12:47 AM   #4
TachyonS14
TachyonS14's Avatar
TachyonS14 is an unknown quantity at this point
Send a message via AIM to TachyonS14
215's on a 9 inch rim? That's a little small don't you think. I know for "uber cool drifters" they like strechting tires, but what if he doesn't drift.
1997 240sx 5spd
TachyonS14 is offline   Reply With Quote
Old 01-15-2005, 01:25 AM   #5
neilio85
Ya I wouldn't consider myself a drifter by any means. I just want my car to have a nice low stance with wheels that fit the car well and are flush for now. Also revat619 could you post up some pictures of your ride. It sounds really nice.
Old 01-15-2005, 01:30 AM   #6
NZO
NZO's Avatar
NZO is an unknown quantity at this point
Send a message via AIM to NZO
I'm just a pretend drifter so I run 5mm front spacer and 245/40s. Its not at all flush with these specs, I would need a larger spacer, but there are a ton of combinations, just depends on what youll be doing with the car.
sentinelguild.com/nzo/PFCDB/
NZO is offline   Reply With Quote
Old 01-15-2005, 01:51 AM   #7
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
I run BNR33s with 20mm spacers front and rear on S13, pulled and rolled fenders, 215/45 up front, 235/40 rear. Camber is like -2.5 and -2.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 01-15-2005, 01:57 AM   #8
neilio85
Post pics of your R33 set-ups guys.
Old 01-15-2005, 02:24 AM   #9
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
wats the offset on the stock r33 wheels. just want to know for reference.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 01-15-2005, 02:27 AM   #10
Logan
Logan's Avatar
Logan is an unknown quantity at this point
Send a message via AIM to Logan
16 x 6.5 i think, offset i'm not sure...probably in the 30s, don't think you'd want em...
if you search hard enough, many on the board have/had s13's with R33 wheels (hint: PG folk)
Logan is offline   Reply With Quote
Old 01-15-2005, 09:30 AM   #11
neilio85
r33 gtr wheels are 17x9 +30 offset
Old 01-15-2005, 09:38 AM   #12
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
they will be FLUSH in the rear thats for sure. Ive got 8.5 rears with a 37mm offset and they're flush. My fronts are 7.5 with a 22mm offset and are flush as well. I wouldnt run any spacer. And for tires on a 9inch rim, do you autoX or road race on these? If so, you obviously want a good amount of rubber, id go 245s all around. It'll handle like a beast. If you'd just rather it look cool for the street, run a 225 up front, and a 245 out back. NO spacers will be needed.
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 01-15-2005, 09:56 AM   #13
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
then you can run 235/40 or 245/40.
revat619's car isnt uber cool, its uber GANGSTER... j/k he daily drives his car, not real issues, tires wear rather evenly, just fast.
based on what the poster is doing, it seems like he is going for the common style, but i could be wrong.
Grant is offline   Reply With Quote
Old 01-15-2005, 11:53 AM   #14
neilio85
No I don't auto-x or roadrace, but wouldn't mind trying it out eventually. For now the car is just purely a street car. I think my best bet would just be to get the rims mounted with coilovers on either 235/40 or 245/40 tires and then decide after if I wanna get spacers to push them out a little bit more. What do you guys think?
Old 01-15-2005, 11:58 AM   #15
Demik
Demik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of lightDemik is a glorious beacon of light
Send a message via AIM to Demik
just get fn01r and call it a day....
but nice choice in wheels keep it gangster!
Demik is offline   Reply With Quote
Old 01-15-2005, 01:23 PM   #16
Grant
that's Jay's car.
Old 01-15-2005, 02:19 PM   #17
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
DO NOT take wheel tire advice from just anybody on here. eveyrone has their own version of "cool". some people think that the smallest tire possible on a 9 inc h rimis awesome. i, however, think that a 215 on a 9 inch rim is queer.
here's what i'd do:
mount the rims to see where you sit as far as offfset and clearance. look around to see how much space you have for tire.
then get as much tire as possible
235s at LEAST for an S14. we S13 fellas are stuck at a measely 225.
MakotoS13 is offline   Reply With Quote
Old 01-15-2005, 03:33 PM   #18
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
here's what i'd do:
A 215 is queer but a 225 is ok???
lilredstiffy is offline   Reply With Quote
Old 01-15-2005, 03:47 PM   #19
MakotoS13
MakotoS13's Avatar
225 is max for stock S13 fronts unless ya wanna rub. unless i've been ill-informed. 225 on 8's is okay for the front but there's no way i'd stick a 9 up there if i could avoid it.
Old 01-15-2005, 04:15 PM   #20
neilio85
that car looks so hot. I think eventually I will end up getting spacers. I read somewhere that a 5mm spacer will be needed anywayz to clear coilovers in the front. Is this true for KTS coilovers on an S14? Anywayz I thought I would post a pic of the wheels that are on their way from Japan and my car.
Old 01-15-2005, 07:58 PM   #21
nlzmo400r
itll look sweet as hell, and yes, just put em on (id run 235s up front, and 245 out back, and then itll look good, and still lay down decent rubber) and then if you'd like, add spacers, just watch wheel stud length. And yes, 225 is about as wide as you can go on an s13, unless you have insanely low offset wheels. Ive got 16x7.5 up front with a 225/45 yokohama and it rubs a LITTLE bit, but not enough to affect anything.
Old 01-15-2005, 08:12 PM   #22
Sil Beer S13
Sil Beer S13's Avatar
Sil Beer S13 is on a distinguished road
Send a message via AIM to Sil Beer S13
I would run what brian and lindsey said.
Sil Beer S13 is offline   Reply With Quote
Old 01-15-2005, 11:14 PM   #23
wylin
wylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud of
i'd run 225/45 (or 40)R17 up front and see if your coilover clears if not start adding spacers, out back run 225-255 width tires, its up to you if u want to stagger the set up.
2003 G35 sedan, 03 m45, 06 S2000
wylin is offline   Reply With Quote
Old 01-16-2005, 12:48 AM   #24
neilio85
What kind of differences will a staggered set-up make/ what will it affect?
Old 01-16-2005, 01:58 AM   #25
NervGS
NervGS's Avatar
NervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant future
Send a message via AIM to NervGS
I know one or two people running 245 up front on an S13 and not rubbing. Thats with stock fenders.
-glenn
NervGS is offline   Reply With Quote
Old 01-16-2005, 02:16 AM   #26
HyperTek
could mean the night/day difference between oversteer and understeer. All depends on air pressure and the actual tire itself too (series, compound etc)
Keep it Classy
Old 01-16-2005, 02:40 AM   #27
final act
final act is an unknown quantity at this point
Send a message via AIM to final act
I want some r33 gtr rims, they are sexay!
final act is offline   Reply With Quote
Old 01-16-2005, 11:56 AM   #28
Grant
i ran 225 up front and 235 in the back with no rubbing issues on my s13 with a 17x9 +18 all around. front fenders were rolled, but didnt need to be. I also depends on how much camber you run and how low you want the car to be.
Old 01-17-2005, 09:24 AM   #29
nlzmo400r
well with my setup (225up front and 245 rear) i ran my first autoX yesterday and took first in my class. I ran about 2.5 degrees of camber up front, and about 1.5 in the rear. There was minor understeer (nothing like my 205s all around though!) however i corrected most of it with a little more camber and a drop in tire pressure. Ran VERY well.
Old 01-17-2005, 10:13 AM   #30
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
the r33 wheels also came in +40 (unless i misinterpreted the translation in the dt mag) but otherwise, just do what brian or doriftoslut says.
KoukiMonster is offline   Reply With Quote
