Old 05-03-2019, 06:02 AM   #1
akruger34
akruger34 is an unknown quantity at this point
550 Denso setup
I was given these injectors in a box with my SR swap, I am trying to get them set up for a new turbo. My questions are:
Do I need to run the blue brackets?
Do I need an o-ring on the tip? I've seen some that have them and some that don't. The middle ring seems to be at the same level as the oem.
When I rewire these for the new plugs, are the wires/pins in the same orientation as factory?
http://imgur.com/ReZvCwh
http://imgur.com/gZBKuS9
akruger34 is offline   Reply With Quote
Old 05-03-2019, 06:04 AM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
test fit them with and without, and see what happens
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
