Old 01-17-2005, 02:49 PM   #1
-usmd-180sx
-usmd-180sx's Avatar
-usmd-180sx is making a name for him/her self-usmd-180sx is making a name for him/her self-usmd-180sx is making a name for him/her self
Dies while driving! Red-Top. NEED SR20 TECHS HELPS!!
So.. ive been having this problem for a while when i am driving my car, say in 2nd or 3rd gear.. and as i am decreasing in speed to come to a stop.. it dies WHILE it is still in gear. STILL IN MOTION.. But all of the dash lights come on like i am about to start the car.. This problem is a very random non frequent problem.. but wat worries me is if it happenes on a off ramp turn. or even on a busy freeway. Luckily, it only happened late night cruising on local streets.
Well, so far i have come to the conclusion it might be a Fuel problem, distributor, o2 sensor needs to be plugged in, MAFS, or maybe a leak of some sort some where... But at this moment.. i am so fkn clueless
Any input would be appreciated and also for the ppl that had similar problems.. it would be helpful for u to compare our problems also.. thanks
Redtop Sr20
Stock, stock, stock
Walbro 225
-usmd-180sx is offline   Reply With Quote
Old 01-17-2005, 03:44 PM   #2
Just8aV8
Just8aV8's Avatar
Just8aV8 is an unknown quantity at this point
Send a message via ICQ to Just8aV8 Send a message via AIM to Just8aV8 Send a message via Yahoo to Just8aV8
i had a similar problem, mine was my maf, but i would suggest to clean your maf, and check to make sure all your intercooler piping is connected securely. also check your fuel filter, although i doubt it.
Just8aV8 is offline   Reply With Quote
Old 01-17-2005, 05:44 PM   #3
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
sr20's dont have a distributer. Some people have this problem with atmos. bov's but yours sounds like its something else since you probably still have the recirc valve. I would check the tps voltage and adjust the idle screw. When mine was stalling the tps voltage was around .35v and it should be more like .50V with the throttle closed.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 01-17-2005, 06:26 PM   #4
driftstyre
driftstyre's Avatar
driftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond repute
Send a message via AIM to driftstyre
check the 12V supply to the ECU and especially the wiring under the dash/passenger side ECU location.
driftstyre is offline   Reply With Quote
Old 01-18-2005, 08:26 PM   #5
ace240sx
ace240sx is an unknown quantity at this point
Make sure your motor is properly grounded to the firewall. Sometimes teh connection becomes corroded or even loose, and then the car will stutter and shut off.
"we endorse beating kids faces in as soon as probation is over and we relocate back to so cal"
ace240sx is offline   Reply With Quote
Old 01-21-2005, 01:28 PM   #6
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
sounds alot like an atmos. bov problem...even when i had my swap done, the stock bov was left open atmos. and the car ran very very rich and wanted to stall frequently especially when decelerating......what kind of bov setup do you have??
bshotts is offline   Reply With Quote
